Originally Posted by MetroMPG
Sludgy, is this a test? Or just a question
LOL It's not a test......and it's sorta a question:
Theoretically, fewer bigger cylinders may be more efficient than small cylinders, because 4 (say) small cylinders have more piston, cylinder head and cylinder wall area than a single large piston. This larger area allows more heat to leak out of the cylinder instead of doing useful work.
On the other hand, a big piston and rod is heavier, and might create more friction. Which wins, reduced friction, or reduced heat loss?
Going back to an earlier thread, my Chevette 4 cylinder was rated at 63 HP and got 40 mpg. Early Volkswagens made 37 HP from a 4 cylinder engine. Chevy makes a 2.8 liter 4 that makes 175 HP. A 1 cylinder version of this Chevy engine would make 44 HP, more than enough to power either car.
But would a 1 cylinder engine use significantly less fuel that their original four cylinder engines?
