OK, I gotta brag about my 99 Civic HX M/T! - Fuelly Forums
Old 07-17-2008, 10:59 AM   #1
I never knew my 1999 Civic HX was a 50+ mpg hwy car! I just did a long road trip, Houston to Chicago and back! I set several records, but also had really bad luck!
1st record - Houston to past Little Rock, 502.3 mi with 190 mi A/C on, 50.1697 mpg, half tank mark at 370 miles! Drafted a semi for 55 miles.
2nd record - North Memphis to Chicago, no A/C 508.6 mi at 50.252 mpg, 358 mi at the half tank mark! No hypermiling.
Total cost in gas Houston to Chicago $94.04 [had a bad top off tank of 26.58 mpg 2.76 gal - bad pump].
3rd Final record - Chicago to North Memphis, 486.6 mi 51.151 mpg with 56.6 mi of A/C, 393 to 400 miles at the half tank mark! I could have broke 52 mpg with no A/C! No hypermiling, except for coasting in neutral down a long slope.
All above driving mostly at 70 mph.
Then incredible bad luck after my record 51.151 mpg tanks! - Filled up the next 2 tanks with Shelll and Citgo and my half tank mark for hwy driving were at 270 and 240 miles - suddenly really bad mpg [all A/C]! And my last fillup was real bad too - 30.97 mpg! I'm wondering why the sudden bad mpg!? Maybe they gave me E85, and I'm trying to get rid of it! No check engine light or codes, my synthetic oil now has 8000 miles, and I recently did a valve adjustment and PCV Valve change around 102,000 miles. Now I have 111,000+ miles.
Anyone know what went wrong with my HX?
JESSE69 is offline   Reply With Quote
Old 07-17-2008, 11:14 AM   #2
GasSavers_BEEF's Avatar
I have had really bad luck with E10 and they don't have to tell you that it is E10 either. Wal-mart gas is like that. they say it is enriched with ethanol. my wife used to get the stuff and talked about how her mileage was sucking. it isn't worth the nickel cheaper a gallon because of the worse mileage.
I don't know if this is your issue or not but it may be.
Old 07-17-2008, 12:51 PM   #3
1993CivicVX's Avatar
I use E10 and I have been getting 65mpg. But I drive much slower than 70mph and hypermile extensively and over inflate my tires and drive a VX. Maybe I'll do a tank or two on non E10 gas sometime and compare.
three stripes the charm!
Old 07-17-2008, 05:04 PM   #4
where do you buy gas w/out ethanol?
Old 07-17-2008, 05:14 PM   #5
Nowhere around here.
regards
gary
Old 07-18-2008, 06:51 AM   #6
Could my thermostat have gone bad causing me to run rich and get bad mpg?
Old 07-18-2008, 08:43 AM   #7
wouldn't you notice that on your temp gauge?
Old 07-18-2008, 09:36 AM   #8
My temp gauge is in the ok range. Maybe my car is stuck in a rich injection startup mode somewhat?
Old 07-18-2008, 10:44 AM   #9
you could always get a scangauge and look at open loop vs closed loop, A/F ratio, load, all that good stuff.
it is a little heavy on the pocket book though ($170) but most people swear by it. I like mine and would recomend it as long as budget allowed.
Old 07-18-2008, 11:55 AM   #10
I have the Dashdyno SPD, and it cost me $370! I guess I can look all that up too. Plus do data logging and 0-60 tests.
Toyota Yaris NorthAmerica 2007/2008 RningOnFumes Car Reviews 16 01-29-2008 11:59 PM
Alternator/battery light problem basjoos General Maintenance and Repair 9 11-24-2007 10:29 AM
$1790 honda insight (san diego) budomove For Sale 3 11-23-2007 05:22 AM
I hear crickets GasSavers_davens General Fuel Topics 18 07-24-2006 08:01 PM
Sharing Indexing Washers SVOboy General Fuel Topics 0 04-01-2006 02:36 PM
