Oil viscosity - more difference than I would have thought - Fuelly Forums
Old 08-13-2010, 05:58 AM   #1
i-DSi's Avatar
Re: Oil viscosity - more difference than I would have thought
Don't forget one of the most important things to let an engine run on 0W20 is an oil pump with a high flow on low revs (in combination with the narrower tollerances).
Bowtie, I don't really understand what you mean with 'it's possible some manufacturers use 0w20 to achieve better EPA estimates and fewer emissions, but at the expense of lubrication.'. I assume you talk here about the fact that a thinner oil does not perform as good as a thick oil at very high temps in combination with high pressure? But these circumstances do not occure that often. What does occure at every cold start is that a thick oil is by far not as fast where it needs to be than the thin oil. So lubrication might be better in real life with the thin oil.
i-DSi is offline   Reply With Quote
Old 08-13-2010, 06:30 AM   #2
a true synthetic 0w30 is just as good at start-up as 0w20, but's it's FAR superior in lubrication, longevity, heat protection, cold weahter performance,etc. what i'm suggesting is that manufacturers use the cheapest methods available to achieve certain #s, irrespective of the interest or longevity of the vehicle.
remember toyota's recent issues? to be fair, shortcuts(and cost cutting) has affected several auto makers in recent years.
edit: 0w20 is likely fine for winter/cooler climates.
WTB: VX Cluster limerence Wanted to Buy 1 05-28-2008 07:45 PM
Are these wheels worth it? Improbcat General Fuel Topics 17 05-24-2008 04:01 AM
Second odometer for WVO tank? Jetta90GL Vegetable Oil and BioDiesel 2 03-24-2008 12:17 PM
New HHO Setup nsgrossman Experiments, Modifications and DIY 4 02-08-2008 12:57 AM
