Oil Pan Heating Pad - Fuelly Forums
Old 12-16-2008, 12:38 PM   #1
aalb1's Avatar
Oil Pan Heating Pad
In the spirit of a block heater has anyone tried an Oil Pan Heating Pad? I assume since Most ECU look at the coolant temp opposed to the oil temp. It may not be as effective in saving fuel on cold starts but I still assume it will help. Just looking for some feedback.
http://www.warehouseautoparts.com/Sp...pan_heater.htm
Old 12-16-2008, 08:47 PM   #2
kamesama980's Avatar
I think the idea is as viable, convection and conduction will carry heat to the rest of the engine. conduction will leave the oil cold as can be with a block heater and on a cold cold day I've had thick oil make a huge difference in the engine's ability to run.
-Russell
Old 12-16-2008, 09:32 PM   #3
Member
Geonerd's Avatar
Well, it's only 150 watts. Most block heaters run 500+, so don't expect miracles.
IMO, the low power rating is probably a good thing. I don't see how warmed oil can conduct heat into the engine effectively. Apart from the edges of the oil pan, only the oil pump pickup pipe touches the oil. Applying the full 500W to the oil would just burn it up, without doing much to warm the block.
Is there a flat area on the front of the block where you could stick another?
-Greg
Geonerd is offline   Reply With Quote
Old 12-17-2008, 04:51 AM   #4
if you want a really good engine heater take a look at the ones that you plumb into the heater core lines under the hood that circulate the coolant while heating it.
zero_gravity is offline   Reply With Quote
WTB: VX Cluster limerence Wanted to Buy 1 05-28-2008 07:45 PM
Are these wheels worth it? Improbcat General Fuel Topics 17 05-24-2008 04:01 AM
Second odometer for WVO tank? Jetta90GL Vegetable Oil and BioDiesel 2 03-24-2008 12:17 PM
New HHO Setup nsgrossman Experiments, Modifications and DIY 4 02-08-2008 12:57 AM
