i did some research on the web and the car is most likely to be OBD 1.5
"OBD 1.5" is a slang term referring to a partial implementation of OBD-II which GM used on some vehicles in 1994 and 1995 (GM did not use the term OBD 1.5 in the documentation for these vehicles - they simply have an OBD and an OBD-II section in the service manual.) ......
......Depending on the year and the vehicle, a car with the OBD 1.5 system may have either the older OBD-I connector, or the newer OBD-II connector, but they are electrically identical to each other.
source:wikipedia
i'll have to have a closer look at the car itself...i haven't spend much time in it... to bad the previous owner took some "souvenirs" like the cars manual, and the special key to unlock my alloy rims
i should be able to find these things from a dead vectra though
