OBD2 tool - Page 3 - Fuelly Forums
Old 10-15-2006, 01:31 PM   #21
Originally Posted by DRW
I wonder what sort of tests MetroMPG will come up with using his new logger? Any plans yet?
- It'll let me look more closely at things like my hot air intake.
Old 10-15-2006, 07:27 PM   #22
DRW
Thanks for posting the links. In the first link to the WAI test you said,"Why doesn't it show up in the results? Perhaps because:
The throttle is open slightly wider, and the effective load is higher. The ECU may be compensating by enriching the mixture."
There is a direct link between engine load and timing. As load increases the ecu will reduce timing. This could be why the WAI didn't work, you had to open the throttle more and that put you down on a lower timing level. So what's more efficient, a stoich mixture with high timing or a lean mixture with low timing? The answer lies in your datalogger.
What would be really cool is if your logger lets you analyze the data in a statistical way, like a 2 way ANOVA. That way you could plug in IAT on one axis and anything else on the other axis and see if there is any correlation. How about IAT vs. fuel trim? IAT vs. O2 readings? Or?
Dave W.
Old 10-15-2006, 07:39 PM   #23
You said it, man.
Sorry. What the heck's ANOVA? Edumacate me please.
Old 10-15-2006, 08:17 PM   #24
DRW
ANalysis Of VAriance. It's a statistics term. It lets you see relationships between two variables even when the two variables are constantly varying.
Clear as mud?
Dave W.
Old 10-15-2006, 08:19 PM   #25
Makes sense.
Old 10-16-2006, 04:55 AM   #26
Stat Progs
Clear as mud?
All I've used in such an application is SPSS for stats. Is there recommended freeware out there that will run statistical applications?
Old 10-16-2006, 05:40 AM   #27
I'd love to have some SPSS freeware.
Got e-mail from the seller: unit shipped this AM air mail. Should have it in 7-14 days. The only unknown is customs fees. That's always hit & miss with international packages. Sometimes I get hit, sometimes I don't.
Old 10-16-2006, 06:00 AM   #28
Hi MetroMPG -¨Sometimes I get hit, sometimes I don't.¨
Consider yourself lucky.
Here every non EU package will get taxed , even gifts from relatives if the customs dept think the value is over $20., and because postage is added to this valu'ing method it means almost everything gets taxed.
Old 10-16-2006, 08:52 PM   #29
DRW
Not that I'm aware of. One of my loggers includes a neat graphing function where I can plug in any two variables and see where each datapoint lies. I find it helpful when looking for relationships between two variables as the datapoints tend to form clusters, lines or scatter. I tried to get a screenshot of it last night, but the log viewer doesn't seem to support it.
I have a feeling the new OBDII logger will give you plenty of data to crunch. Some sort of statistical tool can be useful if the data becomes overwhelming.
Dave W.
Old 10-23-2006, 10:56 AM   #30
Nerd alert update: OBD2 tool arrived. I'll hopefully give it a try this evening and report back.
I saw the same tool sell for $10 less on eBay this week ($45 shipped). So if it works, might be one to watch for.
EDIT: PS, didn't get hit with duty. Nice.
Fuelly Mobile Location Data xbadcrcx Fuelly Web Support and Community News 4 06-29-2011 06:00 AM
How Much Is The Average Price For "minty Clean Vx Wheels"?? panamacolin General Fuel Topics 5 08-23-2007 07:44 PM
2006 xB grille block panels installed GasSavers_Graeme Aerodynamics 7 06-28-2007 12:49 PM
ScanGauge Hockey4mnhs Hypermiling 0 02-05-2007 07:01 PM
OLED's are here - Organic Light Emitting Diodes GasSavers_DaX Automotive News, Articles and Products 4 04-20-2006 05:14 PM
