OBD2 scantools and engines - Fuelly Forums
Old 11-10-2009, 05:12 PM   #1
Lightbulb OBD2 scantools and engines
Hi,
I am new to this forum, so I am sorry if this is offtopic or was already discussed. Anyway, search did not find anything useful, so I am posting this question.
I own a diesel car (as very common in Europe where I live) and I would like to know more about OBD2 diagnostics related to petrol (ehm, diesel) saving.
I have recently bought http://www.obdtester.com/elm-usb cable for use with free (and open source) pyOBD: http://www.cs.unm.edu/~donour/cars/pyobd/ . It works quite OK, but I do not know what should I watch in the application. I have no fault codes stored in my car (so it should be OK), but I would like to know what should measured values (live data) display, what range should it be, how should it change when I push pedal, etc. I understood that fault code is present when something is really really wrong, but this is not my case - I just want to know that everything is 100% condition and my car is not consuming more than necessary. Any help?
Thanks,
Jan
JanK is offline   Reply With Quote
Old 11-11-2009, 03:20 AM   #2
GasSavers_BEEF's Avatar
one of the biggest things you can use this for is to modify you driving style. most people don't realize that you can increase your efficiency by about 30% just by modifying the way you drive the car.
I personally have a scangauge II (www.scangauge.com) it will show you in real time your MPG along with trip MPG and other things. I use mine for IAT intake air temperature as I have a warm air intake on my car and run 150 degree intake temps (that is in degrees F not degrees C).
I would have recomended the scangauge first because it is a small display and you don't have to lug around the laptop with you. you do have the option of data logging which the scangauge does not have.
Old 11-14-2009, 02:39 PM   #3
Post
I did not mean to watch anything while normally driving. That's dangerous and I have built-in trip computer for this purpose.
What I meant is to understand "measured values", i.e. what should I watch to see if anything is getting wrong with the engine and should be replaced to keep petrol consumption low. With measured values I mean this function:
also single-measurement function might be of use. more images of functions or here.
By the way, my diesel car says "Not intended to meet any OBD-2 requirements" ;-).
Old 11-14-2009, 04:13 PM   #4
I think OBDII is a united states thing (or maybe EPA which is also US).
many times, the particular readings are just the values at a given time. the 23 degrees C is probably normal for the time of year. it is about 65ish degrees F and would probably be much lower in the winter.
I would say that depending on how new it is, you probably won't see anything out of the ordinary unless it is throwing a code or something. I will admit that I am not an expert but just as an example a while back, my car lost about 2-3 mpg and I couldn't figure out why. I chocked it up to a funny fill on the tank (that does happen sometimes) and during the next tank, my check engine light came on stating that my EGR valve was faulty. I cleaned it and my mileage came back.
my car is 13 years old and has 192,000 miles (~308,000 kilometers) so things come up on it from time to time.
I will also say that diesels are different creatures too. I have never owned a diesel and the diesels we have around here are monsters (mostly in 3/4 ton trucks) my brother-in-law has one but there again it is a 7.3 liter and will haul a house (maybe slight exaggeration there)
