NOS Idea. - Fuelly Forums
Old 12-06-2005, 11:55 AM   #1
NOS Idea.
What about always injecting tiny amounts of NOS and thus to be able to lower the combustion temperatures and also increase the power of continually lean burn conditions in order to get fuel economy?
Can NOS be produced at home ?
Capcom is offline   Reply With Quote
Old 12-06-2005, 12:34 PM   #2
Nope, no home production,
Nope, no home production, but look into water injection, same idea of cooling the combustion temperatures. Allows you to advanced timing for more power and decrease fuel injected also. :-)
Old 12-06-2005, 12:55 PM   #3
I've just litely read about
I've just litely read about water injection, sounds like a neat and difficult idea.
If this works out well though, why do we worry about water in the tank? especially in the small amounts that may get in there
chesspirate is offline   Reply With Quote
Old 12-06-2005, 12:59 PM   #4
Water in the tank messes up
Water in the tank messes up the fuel, but this water is basically misted into the air stream to make it more humid, so it doesn't fuss with the fuel as much, at least I'm thinking. Water injection isn't so hard, check out the article on it, ;-)
Old 12-06-2005, 02:12 PM   #5
FE nut
diamondlarry's Avatar
Water in the gas can be hard
Water in the gas can be hard on fuel pumps and fuel injectors.
2007 Prius,
Team Slow Burn
Old 12-06-2005, 04:49 PM   #6
Compaq888's Avatar
Injecting small amounts of
Injecting small amounts of nitrous isn't going to get you anywhere. A proper nitrous system costs $450 plus another $100 for a good bottle heater. If the nitrous solenoid were to leak you would have leak of nitrous into your engine and over an amount of time your engine will be gone. The best uses for nitrous is at a track and with Intake and Header and electronics that cut the nitrous off right before your redline.
Old 12-06-2005, 06:37 PM   #7
Matt Timion's Avatar
Re: Injecting small amounts of
Not to mention a lot of the serious racers will actually rebuild their engine after every race.
Old 12-07-2005, 12:56 AM   #8
Compaq888's Avatar
Well it depends. The only
Well it depends. The only people I see that do that are running 7's in the 1/4 mile. Either that or some idiot injecting a huge shot into a stock engine. If the engine is 2 liters or smaller I wouldn't do any higher than a 55 shot. If it's like 1.5L I wouldn't do higher than 50 shot. For mine I used to do 75 shot, but it's a 2.4L
When you go to V-6 you can inject up to 200 shot safely, the higher the number the more stuff has to be upgraded. For 200 shot you'd have to have a 255 pump, fpr, make sure your A/F ratio is good, or have some controller.
If you're looking for better mpg do some wind diffuser stuff, pump up your tires, change your driving.
Old 12-07-2005, 01:14 AM   #9
I know water injection.
Old 12-07-2005, 01:15 AM   #10
What does EGR do ?
What does EGR do ?
Help Needed! thewolfwagon Fuelly Web Support and Community News 2 05-17-2012 04:44 PM
Car not showing in browse vehicles Armegatron Fuelly Web Support and Community News 1 01-17-2012 03:15 AM
electricity / kWh fuel type kal Fuelly Web Support and Community News 4 03-24-2011 02:08 AM
Fuelly for international? pixelthing Fuelly Web Support and Community News 8 08-11-2008 07:32 AM
OBDII Questions krousdb General Maintenance and Repair 1 05-07-2006 04:18 AM
