Nissan Altima REAR wind diffuser/belly - Page 3 - Fuelly Forums
Old 01-31-2006, 03:48 AM   #21
Compaq888's Avatar
Before I went to sleep I
Before I went to sleep I came up to the car and the whole left side of the bumper the tape came off. So I redid the whole bumper with like 3 layers of tape. It better not come off or I'll do 10.
Old 02-01-2006, 10:09 PM   #22
Compaq888's Avatar
I have the mpg results. I
I have the mpg results. I added 2 psi to the tires and that is with the belly.
I drove 69.1 miles on 1.784 gallons of fuel = 38.733 MPG
Before I got 32-33mpgs. Also my fuel gauge barely moved.
Old 02-02-2006, 03:51 AM   #23
rear pan
WOW now I gotta do my rear pan on my xB - tape is not permanent and will always let go - a really heavy sticky shipping tape may work better that duct tape until it gets wet a few times. Better to tuck the rear edge above the bumper if you can then secure the leading edge with bolts and nuts.
Old 02-02-2006, 04:48 AM   #24
Re: rear pan
Good idea, or I was thinking some sheet metal screws. Possibly
use some of those padded washers, and screw the plastic bumper
material down tight against the belly pan. Nice Work Compaq!
RGR... is offline   Reply With Quote
Old 02-02-2006, 06:44 AM   #25
Compaq888's Avatar
Just a warning to you guys.
Just a warning to you guys. Tape and the metal won't last long. My tape is holding on for dear life and the metal is bending. I'm going to try to fix it today. There is just too much force on the metal from freeway speeds.
Old 02-02-2006, 06:47 AM   #26
kickflipjr's Avatar
Rivits would be much better.
Rivits would be much better. Thats what i will use if i ever make one
2008 EPA adjusted:
Old 02-02-2006, 09:42 AM   #27
large areas
Yeah you have to figure the area that is exposed to the air flow - the bigger it is the more forces are on it. That's why I recommend fastening the leading edge well so that back end can blow out adn still be connected to the chassis without the leading edge scooping in more air. I am thinking some glass and epoxy over mine to strengthen the foam board and giving it a lot of open space on the sides to allow air to flow across it and cool the muffler. Time for a "before" shot while the camera is all charged up and the sun is shining. It can be so embarrasing when a chunk of your car falls off on the highway!
Old 02-02-2006, 01:28 PM   #28
Re: Rivits would be much better.
Yeah, rivets would be best. BUt I'd still use screws while testing,
then rivets for the final install. If you are like me (and compaq apparently)
it will be on and off there several times!
Old 02-07-2006, 07:11 PM   #29
Compaq888's Avatar
The belly keeps coming off.
The belly keeps coming off. It doesn't matter how much tape I use or where I use it, it keeps coming off.
There are 2 possibilities...
1) too much wind
2) the metal piece is too heavy for the tape
I can't put rivets or screws because I plan on selling the vehicle.
Old 02-07-2006, 07:14 PM   #30
Who's going to notice a
Who's going to notice a screw hole in some plastic under the car?
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 11:26 AM
Add car brandonrossl Fuelly Web Support and Community News 3 08-22-2010 07:27 AM
An idea for something new. DTMAce Fuelly Web Support and Community News 2 11-30-2009 02:55 AM
Modify O2 sensors zpiloto General Fuel Topics 25 08-04-2006 12:11 PM
