New tires = lower MPG - Fuelly Forums
Old 05-22-2010, 03:11 AM   #1
Site Team
I was doing some reading on rolling resistance, and found out that new tires will typically decrease MPG because of increased RR (and the fact that the odometer is turning slower due to larger OD). Pretty interesting articles over at TireRack.
It also means that a Toyota Prius appearing to get 50.0 mpg just before replacing its worn-out tires with new tires of the same brand, type and size, might be reduced to registering just 47.25 mpg afterwards, even if all of the driving conditions were identical.
http://www.tirerack.com/tires/tirete...sp?techid=177& (You might want to start with parts 1 and 2 first)
-BC
Old 05-22-2010, 04:45 AM   #2
Yup, I've got that info buried somewhere in the huge unwieldy piles of data and hot air in one of my tire threads. Sometimes I mention it in other people's tire threads; I tell them that any new tire is going to have more RR than their worn tires.
The odometer turning slower due to larger OD would affect the accuracy of your FE measurement (making it read slightly less than it really is), but its true effect would probably be a minuscule increase in real FE.
Hey, come to think of it, I wonder if my severely worn tires are part of why my FE seems a little better than it used to be. I'm challenging myself to see how long I can go with them before I put on the replacements that I already have...
Old 05-22-2010, 05:23 AM   #3
I replaced my last set of tires before they were worn down to the point that they would not pass the state safety inspection. I prob ably could have got another 5,000 to 10,000miles out of them before the tread wear indicators popped up, but a fantastic deal came my way on the tires I wanted, so I replaced them.
Old 05-22-2010, 11:35 AM   #4
Makes you want to drive around on may pops doesn't it.
Hipermiler
#47 on my way to #1
Old 05-22-2010, 04:42 PM   #5
Lots of great info about tire tech from a tire engineer from NC.
http://www.barrystiretech.com/index.html
want2buyVX is offline   Reply With Quote
Old 05-22-2010, 04:49 PM   #6
That site gets my endorsement, for whatever that's worth. I've liked it for a long time. I find it very informative and there is very little I disagree with there.
Old 05-23-2010, 11:03 AM   #7
gork57's Avatar
I've used 175/70-13 size tires on my '92 Civic VX for years due to lack of availability of quality OEM size 165/70-13s. Any idea how much the larger diameter tires affect my mpg figures? Measured trip odometer readings show I get a consistent 40-45 mpg. Am I doing better or worse than that in actual numbers?
Simplicity is the glory of expression.-Walt Whitman
gork57 is offline   Reply With Quote
Old 05-23-2010, 12:05 PM   #8
Assuming that your car has not been adjusted for the new tires, you are getting better fuel economy than your calculations. You can compensate by calculating in an extra 2.5%.
Old 05-23-2010, 12:46 PM   #9
http://www.miata.net/garage/tirecalc.html
Hipermiler
#47 on my way to #1
Basic Stats poorboymeyer Fuelly Web Support and Community News 2 09-22-2009 09:19 AM
Performance Underdrive Pulleys? cfg83 General Maintenance and Repair 10 09-08-2007 09:04 PM
hello, found your site through reading an article. wireless0ne Introduce Yourself - New member Welcome 3 07-12-2007 09:03 PM
Bought new BFGoodrich Long Trail T/A Tires Bill in Houston General Fuel Topics 0 06-29-2007 01:56 PM
The state of commuting in America theclencher General Fuel Topics 32 10-21-2006 07:21 PM
