new scangauge - Fuelly Forums
Old 02-22-2013, 11:29 AM   #1
new scangauge
Gents:
Just installed this in my 2000 civic ex 5sp . Lots of outputs to choose from. Any suggestions on which ones to monitor?
Northwoods
northwoods2 is offline   Reply With Quote
Old 02-22-2013, 11:45 AM   #2
GasSavers_BEEF's Avatar
I do instantaneous MPG, average MPG, water temp, and incoming air temp.
I will say that I have had issues with my coolant temps (water pump, and coolant leak) which I have since squared away and I have played with a WAI so that is the reason for those two.
I know that percent load is a good one and throttle position is another good one.
definitely use the X-gauge to make the average MPG tab. that is a handly little thing there.
Old 02-22-2013, 04:49 PM   #3
I like instant MPG, trip average (think that's an XGauge), coolant temp, and (in my automatic) trans temp (XGauge).
Old 02-22-2013, 05:19 PM   #4
Beef:
how is the xgauge mpg different from the instant mpg?
Old 02-22-2013, 06:49 PM   #5
If you set up a trip MPG via the X gauge, it gives you a running average that resets when the car is off for around 3 minutes. thus it gives you an approximation of your mileage on say your trip to work. that is handy when gauging how much better you do without having to do an entire tank.
it gives you a wider window into your actual mileage. the instantaneous mileage varies and bounces a lot... you'll see.
Old 02-23-2013, 06:46 AM   #6
Got it. made program change last night. will be doing 195 deg thermostat next.
northwoods (of mn - man its cold up here...)
New 2009 Aveo sedan 5 speed, replaces 1993 Honda Civic LX. Ref Fit, Yaris, Corolla, marcb Introduce Yourself - New member Welcome 8 03-26-2010 10:08 AM
Crazy or not, I am here.. 1=2 Introduce Yourself - New member Welcome 4 06-26-2009 04:34 AM
Someone scratched up my car!!! AMX General Discussion (Off-Topic) 2 06-07-2008 12:43 PM
Anyone have experience making their own solar panels? MetroMPG Electric and Solar powered 17 08-29-2007 06:43 PM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 06:02 PM
