Negative camber to decrease rolling resistance - Fuelly Forums
Old 02-26-2007, 07:16 PM   #1
I just had this thought and was wondering if anyone has set up their suspension with negative camber(top of tires tilted in) in order to reduce contact patch and rolling resistance. I dont see why this wouldnt work, but I dont know if the gains would be measurable. The negative camber would have to be offset with a small amount of toe out to negate the tires tendency to roll towards each other when they are tilted. This would help traction on hard cornering enabling one to hold speed better, especially on a car with lots of body roll. Braking would be slightly hindered. I imagine this would enable you to effectively lower rolling resistance while increasing cornering capability.
Worth trying? I dont know...
hotroddr is offline   Reply With Quote
Old 02-27-2007, 05:41 AM   #2
I don't see how it would work to reduce rolling resistance... after reading the materials I found on tire rolling resistance and accepting their premise that sidewall flexure causes most of it, it looks to me like anything other than 0 camber would cause increased sidewall flexing and the tread is still likely mostly flat to the road so...
But it does make sense to me how it can improve cornering capability.
Godyear says that the TREAD causes most of the rolling resistance.
http://www.goodyear.com/truck/whatsn...ckFactors.html
Old 02-27-2007, 12:20 PM   #3
If the tires are overinflated enough to prevent the majority of sidewall flex though, it might help slightly. I saw a picture of a pickup truck on two wheels with 100 psi front and back, and the tires held their shape. There was very little flex and the wheels were still rectangular when looking at it from the front. I think that it's in the same police article that was about the safety benefits of overinflation.
Old 02-27-2007, 12:24 PM   #4
omgwtfbyobbq's Avatar
The stunt drivers should know a thing or two about deflection under load. Just don't hit any potholes...
Fuelly Mobile Location Data xbadcrcx Fuelly Web Support and Community News 4 06-29-2011 06:00 AM
Graphs itsastationwagon Fuelly Web Support and Community News 2 08-13-2008 03:04 PM
Both odometer and trip mileage? tiffehr Fuelly Web Support and Community News 1 08-08-2008 05:55 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 08:27 AM
What's the point of living anymore??? (personal stuff- If you don't like reading personal stuff then don't open the thread) Compaq888 General Discussion (Off-Topic) 38 04-03-2006 11:30 PM
