Originally Posted by cheapybob
Its the final drive ratio in top gear that kills DOHC mpg's, I think. If you ever need new tires, get the tallest, thinnest, high psi LRR tires on the front that will fit.
You know, there aren't very many options, at least not in 15 inch.
I was looking into that, since I will need new tires anyway soon. The problem is that the sidewall for 185/65-15 is already fairly high and there are just no 70 or 75 available.
I looked at 175 and found nothing, there is one Kumho tire in 165/80-15 for $40, but it's on back order and the maximum tire pressure is only 35 psi.
