My roof extension - Fuelly Forums
Old 01-17-2011, 07:41 AM   #1
My roof extension
Prototype materials:
Scrap coroplast, gorilla tape and 1/2 emt conduit.
Final version materials:
Lexan, 1/2 emt conduit, 48x2x.125 aluminum and sheet metal screws.
GasSavers_Jesse is offline   Reply With Quote
Old 01-17-2011, 07:49 AM   #2
Lean Burn Mode
pgfpro's Avatar
Re: My roof extension
Nice work!!!
Have you got any before and after results?
Old 01-17-2011, 11:27 AM   #3
Site Team
Does that affect your vision out the back? (Not trying to be a naysayer, just curious!)
-Bob C.
Old 01-17-2011, 12:02 PM   #4
benfrogg's Avatar
Looking great! Great lexan work! I wish I had the skill do do those complex bends like that!
Do you plan to make this a full boat tail eventually or just a camback?
B
Old 01-17-2011, 03:24 PM   #5
pgfpro - No aba testing, when I started ecomodding this past summer I didn't expect to become so immersed. I do know before the prototype roof ext/kamm in 40 degree temps I would see about 40mpg with the other mods(air dam being most significant). In single digit temps I haven't dropped below 38mpg with no warm up time with this set up, best one tank was 42.93mpg
bobc455 - The prototype did, really sucked because I deleted my pass side mirror. This one is more than sufficient, so long as I keep it clean(salt free). I am thinking of sealing it up so I don't have to clean it so frequently.
benfrogg - It's very easy to do if the curves are gradual enough, and if you use thin enough polycarbonate. I went with .093 thickness, and I didn't use a heat gun, just held it in place while I put sheet metal screws in. It wasn't easy doing it by myself, and all I had to use was a dremel, in person it's far from perfect, but so it the car. Thanks for the comments guys.
CRX Rear Wiper Delete HOW-TO UfoTofU Experiments, Modifications and DIY 0 04-30-2008 04:26 PM
Lean burn idiot light for a VX Sigifrith General Maintenance and Repair 0 09-30-2007 03:24 PM
5W-30 (cheap) to 0W-20 (expensive) Erdrick Experiments, Modifications and DIY 17 07-16-2007 05:42 AM
To all the aero geniuses/creative inventors.... Raccoonjoe Aerodynamics 15 07-09-2007 05:25 AM
The World's Fastest Indian (movie) kickflipjr General Discussion (Off-Topic) 3 09-25-2006 12:19 AM
