My new 2016 CX5 is terrible on fuel - Fuelly Forums
Old 12-14-2024, 04:50 PM   #1
Just picked up a 2016 Mazda CX-5 GS AWD - thing is mint and has pretty low kms with 86,000km. Full maintenance records, inspection, drives clean, I did so much research before I bought this thing.
But it's dreadful on gas in the city. I don't understand why or how but it's significantly below what it should be getting. Highway MPG seems to be on par with what it should be getting. I drive VERY light. I'm trying to do a deep dive on things I can control. I just ran a tank with..
22% highway driving
78% city driving
and it was 12.3L/100km or 19.12MPG and it's rated for 24MPG with 100% city driving..
Stuff to do?
- Cleaning MAF sensor - haven't done this but will look into it
- Spark Plugs? It only has 86k on it, recommended changing at 120k..
- Air Filter - looks super clean
- Ultrasonic clean the Fuel Injectors maybe? My buddy suggested it
- Run 37-39psi on the tires. Spec says to run them at 34psi but this was recommended
- PCV Valve? no idea, buddy suggested to look into this
- Additives like seafoam or fuel stabilizer. Not sure if this would be worth it
Any suggestions are greatly appreciated. I love this thing but man I didn't realize it would have such dreadful consumption in town
Irenicus is offline   Reply With Quote
Old 12-15-2024, 10:41 AM   #2
LDB
That's unusual for a Mazda. I run 3psi above the door placard. Sounds like you've got a good plan with a number of potential solutions. Good luck working it out.
2024 Honda CR-V EX-L 1.5L AWD
Old 12-15-2024, 02:34 PM   #3
The more I research the more it's pointing to being completely normal for stop and go city traffic. Not sure how much of this list would be worth pursuing..
Old 12-15-2024, 08:21 PM   #4
LDB
That's interesting. In the past I had a 3hb and a CX-30 and both pretty much matched their sticker numbers. Neither was AWD though. I'd try the 2-3 psi above door placard but that's just a habit of mine with any car. I don't know enough mechanic stuff to know about the rest. Hopefully you can pick up at least a bit.
Old 12-17-2024, 08:06 PM   #5
How far are you driving in the City? I know one area where it's a stop sign every 2 seconds or hit a lot of lights all cars take a lot of gas.
burge100 is offline   Reply With Quote
Old 02-11-2025, 07:12 PM   #6
22% highway driving
78% city driving Chill Guy Clicker
Stuff to do?
Your highway MPG is fine, so the issue is mainly with stop-and-go driving.
erinrobles is offline   Reply With Quote
Old Today, 08:26 AM   #7
Country: Australia
22% highway driving
78% city driving
Stuff to do?
The 2016 Mazda CX-5 isn’t the most fuel-efficient crossover, especially if it's the AWD model or has high mileage. Try improving fuel economy by keeping tires properly inflated, using high-quality fuel, and avoiding aggressive acceleration. Regular maintenance, like changing the air filter and spark plugs, can also help. If fuel economy is still bad, consider checking for issues like dirty fuel injectors or a failing O2 sensor.
jastingreyyy is offline   Reply With Quote
« Fuel Average | - »
