04-01-2006, 05:16 PM
#51
Quote:accelerate fairly
accelerate fairly gradually (0 to 60mph in about 20 sec)
Wow, you're a quick one!
04-01-2006, 05:23 PM
#52
Re: Well, this im/tb is for you
Originally Posted by SVOboy
Well, this im/tb is for you and you'll be paying for it, so don't go crazy over there,
I think I can get it for 25 shipped with all sensors and injectors and all that good ish.
Ill take it! Heck, the aluminum content alone is nearly worth $25.
04-01-2006, 05:25 PM
#53
It weighs like 10 pounds and
It weighs like 10 pounds and that's mostly the injectors,
04-01-2006, 05:30 PM
#54
Re: On flat roads I go 1st and
Originally Posted by krousdb
On flat roads I go 1st and 2nd up to 2000 and then 5th at about 1000, 25 MPH. Then accel to 35. Instantaneous FE during light 5th gear accelleration is 40-50.
Hill climbing a gradual slope I am in 5th at 1200, holding 32 mph steady,instantaneous FE is 45 . Moderate hill climbing at 4th 1500, holding 32 mph steady, instantaneous is 30. Severe hill climbing in 4th 1500 bleed down to 1000 then 3rd, hold 30mph, instantaneous is 20ish. I am in 5th 90-95% of the time when I drive. At idle in 5th gear, I can hold 20 MPH on a flat road, instantaneous about 100 MPG.
At 2200 lbs, it doesn't take much torque to accelerate or to hold speed. The only time I go over 2000 is when I have to go over 50 mPH. When I get the CX tranny installed, I will never have to go over 2000.
damn i forgot your car is lighter than mine by 200 lbs, what's your engine specs? and what kind of wheels do you have put on right now? here are mine:
Weights: curb weight (lbs) 2,449
p185/70R14 87S
115 HP SAE @ 6,100 rpm; 110 ft lb , 149 Nm @ 4,500 rpm
this is the engine with no vtec. I just did a 3km run and got 55.6 mpg, then I took a 5 min break and did the same run again and achieved 63.5 mpg! for a total of 6 km, which has 2 right turns and three stop signs that i have to turn right on as well. I wonder how many times i can repeat the segment until my mpg maxes out?
lol time to find out
edit: boo 3rd run resulted in 54mpg but then again I took a 10 minute break for that one and when I got back coolant temperature dropped from 90 C (normal operation) to 70C.... but now at least I know what my car is capable of!
04-01-2006, 05:42 PM
#55
I have 102 HP, 98 ft lb
I have 102 HP, 98 ft lb torque. No vtec here either. The wheels are 185/65/15 which are way bigger than the stock 175/75/13. That may be costing me a few mpg. Im working on getting smaller tires/wheels.
04-01-2006, 05:47 PM
#56
I'm not helping either, but trying. VX rims in the hizzouse (in my basement, to be exact).
04-01-2006, 05:52 PM
#57
Re: Quote:I have 102 HP, 98 ft
Wish I could do the 13", but the tire options are very limited. Actually, with the HX rims at 12 lb, and the tires that I found at 13 lbs, the whole works is 25 lbs per wheel. Not many 13" tire and rim combos could beat that.
04-01-2006, 05:54 PM
#58
I'll have to weigh mine, but
I'll have to weigh mine, but also. I could weigh more than you and still have less inertia, especially since the tire weight is mostly at the outside. Think about it...
