07-07-2010, 08:27 AM
#71
Originally Posted by pgfpro
I'm sorry but I'm not understanding your question???
Turbo manufacturers will tell you that there are two things that turn the turbine wheel. Heat and Exhaust flow(temperature and pressure)
I think you agree with the exhaust flow part? On the heat side this is why they use advance materials to make the turbine wheel and when you use header wrap you actually help the turbo spool.
On rear mount systems that I have built and use from a major manufacturer you loose a lot of this energy and usually have to up the size of the turbo hot-side itself because a loss of the turbo's turbine efficiency.
I agree with the exhaust flow part, correct.
On the heat issue, I'm ready to accept that it does what you say it does, but I'd have to understand how it does that.
As I understand, heat cannot itself turn a turbine; it can expand a previously cool gas, which in something like an exhaust system would increase the gas's velocity and pressure, which would certainly turn a turbine. However, in an exhaust system, the exhaust gas is hottest when it comes out of the cylinder*, so it's not going to pressurize any more than it already has between the piston and the turbo.
*: And maybe again when it comes out of the catalytic converter, but that's not relevant here.
07-07-2010, 02:30 PM
#72
i'm not convinced heat yields a measurable amount of increase either. the "new" thing in twin turbos is at the tail pipes--force space constraints as well, obviously. measurably cool by that time?
also, my new turbo Mack truck http://www.gassavers.org/garage/view/969 often keeps the engine running(key off) to cool the turbo before shutdown. the truck is very fast cold or hot(relatively speaking), it doesn't matter.
my speculation is based on experience and suspicion only--no facts or sources.
07-07-2010, 07:00 PM
#73
Lean Burn Mode
Quote from Borg Warner Turbo Manufacturer
The turbocharger turbine, which consists of a turbine wheel and a turbine housing, converts the engine exhaust gas into mechanical energy to drive the compressor.
The gas, which is restricted by the turbine's flow cross-sectional area, results in a pressure and temperature drop between the inlet and outlet. This pressure drop is converted by the turbine into kinetic energy to drive the turbine wheel.
The turbine performance increases as the pressure drop between the inlet and outlet increases, i.e. when more exhaust gas is dammed upstream of the turbine as a result of a higher engine speed, or in the case of an exhaust gas temperature rise due to higher exhaust gas energy.
07-07-2010, 08:38 PM
#74
Lean Burn Mode
Originally Posted by shatto
Interesting is about heat and gas flow. I once read a dissertation on high performance exhaust systems and the end result was that too big wasn't good because of heat loss. Seems the hotter the exhaust at the tip, the better for scavenging. Something like that.
On the other hand, if keeping the heat in was so important one would think Lockheed would have placed the turbochargers on the engines, not 10 feet away on the booms of the P-38. Or used two stage mechanical superchargers like the other inline engines used..
Is it not true that the reason we need exotic high temperature materials for the impeller because they want the turbo as close to the exhaust valves as possible......to overcome....."turbo-lag?" Is that lag not the reason racers who need instant power do not use turbochargers but default to the good old Roots, in drag racers?
On the P-38 and its turbo placement I have no idea why they did what they did. I do hold that plane close to my heart because it was my Dad's favorite plane that he worked on in the Air Force during WWII as a airplane mechanic. In fact I have a knife that he made from a P-38 that was grounded from major Combat fighting. He said he used the propeller, propeller cone and the cockpit glass to make it. Its Cool As Hell!!!
The turbo companies do want the turbo close to the exhaust valve to utilize the heat. Today's turbo's have made major advancements just in the last 10 years. Turbo lag has become a thing of the past with the correct sizing.
Turbo Technology has come a long way.
07-07-2010, 08:42 PM
#75
Lean Burn Mode
Originally Posted by Erik
Keeping the exhaust temp high (with header wrap) will keep the velocity high- b/c the exhaust gas will contract and slow down as it cools. More heat loss between exhaust valves and turbo will mean less energy to spool the turbo.
I think that there are two perspectives going on here about the whole heat vs. velocity argument about what spins a turbo. The heat of combustion is what provides the energy that causes the gasses to expand. The expanding gasses move to an area of lower pressure and as a result there is a pressure gradient. The movement of gasses toward the atmosphere (their mass and velocity) provide the force that spins the turbo.
So, the heat of combustion initially provided the energy that gave the exhaust gasses the force (a function of their velocity and mass) that that they impart on the turbo impeller.
So both camps are technically correct- they are just looking at it from different viewpoints.
Just like wind energy from a sea breeze is technically a byproduct of solar energy because the sea breeze is a result of differential heating of the earth's surface by the sun.
 I think Your right!!!
07-08-2010, 05:58 AM
#76
Ok, I can imagine that heat is conducted out of the exhaust gas through the turbo, so it's cooler and denser on the output side, which could conceivably result in higher pressure on the input side than the output side...and the more dense exhaust gas now requires more energy behind it to get it through the rest of the exhaust system (unless it's a tailpipe turbo).
So far, that gets us to where it is using exhaust energy to shove more air (and therefore fuel) into the engine, reducing pumping loss on the intake but increasing it on the exhaust. At most, if it was a 100% efficient machine, it would seem to come out even.
Erik's explanation makes more sense to me, though.
07-08-2010, 06:58 AM
#77
Lean Burn Mode
This is why I'm now running a a smaller higher compression 1.5L N/A engine to compare turbo engine verse non turbo engine. The first results are coming up that the larger 1.6L turbo engine is more efficient and has better FE. I need to see this first hand to prove it to me and a few other Universities that are interested in this project.
I will also be building a third engine this winter with stock piston to cylinder clearances and stock ring gaps. If anything I have become very good at switching engines out.  I can have a engine and transmission pulled and another one up and running in 50 minutes.
07-08-2010, 07:56 AM
#78
I wish I had that level of skill and experience.
07-08-2010, 10:24 AM
#79
Lean Burn Mode
Thanks Man!!!
Here is what the car looks like as of today. I'm getting the body work already and hopefully I should have it painted by the end of this month so I can get back to testing.
