03-03-2010, 11:10 AM
Lean Burn Mode
Originally Posted by DRW
Oh yeah,
Oil squirters keep pistons cooler so you can run tighter piston clearance. Does your engine alredy have them?
Is there any way you could swap in a taller 5th gear from another drivetrain?
Have you considered using a custom cam with late intake closing to produce a Miller/Atkinson cycle effect?
Unfortunately my Honda doesn't have oil squirters. I'm going to tighten up the clearances next year with the new engine.
I do need a taller 5th gear so i'm going to be swapping in a VX 5th gear.
I'm looking at having a custom cam ground to take advantage of the Miller/Atkinson effect. When I do this I will probably have to increase the compression though?
