My FE/Performance Project - Page 4 - Fuelly Forums
Old 03-15-2010, 02:02 PM   #31
Lean Burn Mode
pgfpro's Avatar
Originally Posted by ben98gs View Post
First off, nice build.
But I agree with the oil return line. Why not at least do it in braided stainless? It would not cost more than probably another $20 or so in that short a length and have a lot better chance surviving if it happened to get a bit closer to the manifold.
Ok I give up and I'm having a "high heat" stainless steel braided hose built.
Old 03-21-2010, 04:18 PM   #32
Lean Burn Mode
pgfpro's Avatar
OK shes running again. Everything looks great so far.
The exhaust system is working out great!!! Very quiet and stealthy.
I'm still going to build a few heat shields(upper radiator hose and between the head and manifold on the dist. side)
Old 03-25-2010, 09:14 AM   #33
Lean Burn Mode
pgfpro's Avatar
A good read on lean burn engines.
http://franzh.home.texas.net/lean.html
Old 03-25-2010, 03:04 PM   #34
GasSavers_maxc's Avatar
Are you going too give that engine better spark?
less lurking and more working
Old 03-25-2010, 03:12 PM   #35
Lean Burn Mode
pgfpro's Avatar
Nope, the stock ignition on these engines are amazing. There are several
500whp 1.6L SOHC Honda's using stock ignitions.
EDIT:
Pic of the Neptune software
Old 04-10-2010, 06:25 PM   #36
Lean Burn Mode
pgfpro's Avatar
Ok I'm thinking about going with a different trans oil.(Ams oil etc)
I have been using Honda's Manual Transmission Fluid (MTF)
Has anyone on here seen any improvements of FE over Hondas MTF???
Old 04-11-2010, 10:27 AM   #37
fowljesse's Avatar
Thanks for that link. I wish i could see your setup in person! It is exactly waht I would hope to achieve if I had the money, and knolwedge t
fowljesse is offline   Reply With Quote
Old 04-11-2010, 12:55 PM   #38
Lean Burn Mode
pgfpro's Avatar
Thanks!!!
Its taken awhile to build it and more money then I wanted to spend but so far has been worth it. The new turbo setup has been giving me some problems but I think I got it figured out now.
My biggest concern now is when I start the dyno testing and hoping that the transmission gears don't go flat on me and hurt the FE side of the setup.
Aren't you in Portland Oregon? If so I will be going through that way when I do my next long trip FE test. My goal is to see if I can make it to San Francisco on a tank of gas.
Old 04-11-2010, 01:59 PM   #39
fowljesse's Avatar
Yeah! I'm in Portland. Definitely let me know when you come through here. I can drive along side you, so you won't have to use extra gas Or you could not count the extra gas to meet me somewhere...
Do you know;
I'm thinking about heating the fuel line to help combustion. Some people said it didn't work, but they didn't have standalone EMS. I can, of course lean it, so the heated fuel would make a bigger difference. Also, theoretically, Acetone loosens the bond of Gas molecules for better atomization. I do see a FE gain when I use it, but haven't used it with running lean yet. I'm also going to put in an MSD6A, even though I've read it won't do much. I already have it, and it won't hurt.
Old 04-11-2010, 05:41 PM   #40
Lean Burn Mode
pgfpro's Avatar
Do you know;
I will definitely let you know when I will be heading your way!
IMHO I think heating the fuel does contribute to better FE. I did some testing last Fall and it look like I saw some gains around 4% in FE. I'm going to make a better system this year. The one I was running last year was kinda ghetto but it worked.
I haven't tried the Acetone deal yet.
higher Octane = Better MPG JBW General Fuel Topics 9 04-03-2012 11:54 PM
1998 Honda Superhawk $2000 OBO cat0020 For Sale 0 10-23-2008 07:42 AM
Anyone hypermile a BMW? JESSE69 Hypermiling 9 06-27-2008 11:29 PM
Rear deflector...posible mpg gains? ZugyNA Aerodynamics 6 01-10-2008 01:40 PM
Happy Birthday Dax! Matt Timion General Discussion (Off-Topic) 0 12-28-2007 02:11 PM
