MPG Cruise Control Algorithm - Fuelly Forums
Old 04-08-2009, 07:35 AM   #17
Code:
int angle, speed, set_speed, min_speed, max_speed, stall_speed, tpsi, tpso, tpseff, ovrdrv;
// Set sensor inputs and constants. In an actual program these would repeat
from within and calculate based on if it was needed or not to keep the processor
from constantly making calculations instead of executing code and also enables
you to set your +- numbers in one spot instead of 500.
input angle;
input set_speed;
input speed;
input tpsi;
set min_speed = (set_speed - 5);
set max_speed = (set_speed + 5);
set surge_speed = (set_speed + 10);
set stall_speed = (set_speed - 10);
set tpso = '0';
set ovrdrv = '1';
set tpseff = '75';
Repeat {
// If your vehicle angle is less than or equal to -10 degrees(downward slope) the
computer will calculate when to get out of overdrive based on surge_speed which
is a pre-programmed temporary speed increase above the normal maximum speed.
By the time you have reached the bottom of a hill you should be at surge speed,
in overdrive again, with no throttle input. That will continue until the car either reaches
min_speed (level ground) or stall_speed (going up a hill again).
		if (angle <= -10) {
			if (speed < min_speed) { set tpso = tpsi + 1 };
			elseif (speed > surge_speed and tpso != '0') { set tpso = tpsi - 1 };
			elseif (speed > surge_speed and tpso = '0') {
			repeat {
				if (speed > surge_speed and ovrdrv = '1') { set ovrdrv = '0' };
				elseif (speed <= (surge_speed - 3)) { set ovrdrv = '1', return 0 };
				else { set ovrdrv = '0'};
			else { set tpso = tpsi };
//If the vehicle angle is between -10 degrees and 10 degrees vehicle speed is
maintained like any other cruise control system.
		elseif (angle > -10 and angle < 10) {
			elseif (speed > max_speed and tpso != '0') { set tpso = tpsi - 1 };
			elseif (speed > max_speed and tpso = '0') {
			repeat {
				if (speed > max_speed and ovrdrv = '1') { set ovrdrv = '0' };
				elseif (speed <= (max_speed - 3)) { set ovrdrv = '1', return 0 };
// If the angle is greater than 10 degrees and actual speed decreases to less
than stall_speed the control system automatically increases throttle to a
pre-determined efficient throttle position, in this case it is 75%. This area needs
work because the program currently would set to the efficient throttle setting
and immediately unlock the torque converter because both of them would then be
true. Then, it would hold that until the surge speed is attained and would exit the
loop only to end up stuck in the 'else' holding 75% throttle until the angle
changes.
		elseif (angle >=10) {
			if (speed < stall_speed) { set tpso = tpseff };
			elseif (speed < stall_speed and tpso = tpseff ) {
			repeat {
				if (speed < stall_speed and ovrdrv = '1' ) { set ovrdrv = '0'};
				elseif (speed >= surge speed) { set ovrdrv = '1', return 0 };
			elseif (speed > surge_speed) { set tpso = tpsi - 2 };
			elseif (speed > max_speed and speed < surge_speed) { set tpso = tpsi - 1 };
// If there is an angle sensor failure it would default to this, essentially making it
a constant-throttle cruise control.
- Kyle
Average fuel mileage line in the history graph? BDC Fuelly Web Support and Community News 1 05-06-2009 12:07 AM
91 CRX DX 5 Speed Head Gasket Confusion UfoTofU General Maintenance and Repair 2 04-26-2008 10:09 AM
Is there a website where I can look up... wehrd1 General Maintenance and Repair 3 04-18-2007 05:23 PM
Congratulations Jared!!! SVOboy General Discussion (Off-Topic) 7 08-13-2006 08:55 PM
