 dkjones96 Sweet! 04-08-2009, 08:06 AM
04-04-2009, 12:52 PM
MPG Cruise Control Algorithm
After analyzing how I'd try and optimize fuel economy if I were limited to only the information available from the OBDII port, I came up with the following. I can think of a few ways to make it more involved, but it may not be necessary so I figured I'd run it by the more experienced hypermilers out there. A simple system couldn't take advantage of anticipation (speeding up before going uphill or coasting to stop signs), but one with GPS could in theory, so as a separate issue, I would love to see any thoughts you have for that algorithm as well. I hope my pseudo-code is clear. I didn't want to create a flowchart.
Repeat { if( speed <= MIN_SPEED ) {// very steep uphill, economy is not the concern
adjust throttle as needed to maintain MIN_SPEED; } else if( throttle <= MAX_EFFICIENT_THROTTLE ) {
// level travel, downhill, and shallow uphill
adjust throttle to be as low as possible to maintain at least LEVEL_CRUISE_SPEED; } else {
// moderately steep uphill
keep throttle at MAX_EFFICIENT_THROTTLE, allowing speed to diminish; }
co de pen den cy
Function: noun
Date: 1979
