most fuel-efficient rpms for subaru? - Fuelly Forums
Old 07-24-2007, 11:57 AM   #1
hi,
I have a 2003 subaru baja and I usually average around 26-28 mpg. The roads I take to work are speed limit of 55, so I usually go around 60, which puts my rpms at 2,800, which I always thought was ideal.
However recently we drove down from Michigan to Georgia and one of the tanks we managed to get 31 mpg! I couldn't believe it since we were following someone and not using our cruise control and even had the air conditioning on for a bit...
all I could figure is the subaru must be more efficient at over 3,000 rpms.
anyone else have any experience with subarus?
GasSavers_McGee is offline   Reply With Quote
Old 07-24-2007, 12:10 PM   #2
What were you following and how far back?
Did the tank before or after have lower-than-expected mpg?
Old 07-24-2007, 12:49 PM   #3
Send a message via Yahoo to GasSavers_BMac
My 96 Outback cruises at 70mph @ 3200rpm and doesn't lose speed on the hills but I can only get 27mpg with it bone stock. And that was from Michigan to eastern Canada and back.
When I first got it last year I was getting 28mpg.
1998 Dodge Dakota Sport 5.2 auto,
Aero Cap,
Cam advanced 4 degrees,
MSD 6TN,
MSD Blaster2 Coil,
MSD 8.5mm SuperConductor wires,
Borg-Warner cap & button
Halo plugs,
PCV jar
and more to come...
GasSavers_BMac is offline   Reply With Quote
Old 07-24-2007, 01:06 PM   #4
GeekGuyAndy's Avatar
With my 97 Legacy wagon I can stay at 3000rpm at 70mph, but don't normally drive that fast.
McGee, I typically drive 55-60 when possible and stay around 2300rpm. I went about 400 miles which was ~90% 55, ~2% 65, and ~8% 45 and under and averaged about 34mpg (without ScanGauge). I don't know why that is so much lower rpm and higher mpg than your Baja. Are you gliding down hills? Gliding in N got me to 30mpg, add DWL and I got 35mpg, add P&G and a ScanGauge and I got 40mpg.
I just did a test yesterday trying burn and glide against pulse and glide, and only using the engine at very high rpms was less efficient.
GeekGuyAndy is offline   Reply With Quote
Old 07-24-2007, 01:43 PM   #5
The Baja is probably a 5-speed MT, and is probably geared lower than your AT, which would make its rpms higher. And its shape is a little less shhmoooth than a Legacy wagon, what with the bed and all, so maybe that explains the mileage. Just my guesses.
Old 07-24-2007, 04:22 PM   #6
But wouldn't a 5sp M/T totally beat a huge wagon 4sp A/T? That's what I don't understand
Old 07-24-2007, 05:19 PM   #7
kickflipjr's Avatar
The general rule is the slowest possible in the final gear would produce the best mpg.
metro speed/mpg graph:
http://www.gassavers.org/showthread....ighlight=speed
crx speed/mpg graph:
2008 EPA adjusted:
Old 07-24-2007, 08:26 PM   #8
Bajas have all kinds of stuff dangling off them like racks and bars and lights and flaps and that bed in the back. The Legacy is nice and smooth. On the highway, I'd bet on the Legacy. In town, I would favor the Baja.
Old 07-24-2007, 08:57 PM   #9
omgwtfbyobbq's Avatar
In order for the EPA highway to be roughly the same, Subaru probably has significantly taller OD for the A/T. The implication being that at a steady cruise with the TCC locked, the A/T with the taller gearing will get better mileage.
Old 07-26-2007, 03:19 AM   #10
My parents legacy (2001 2.5 L 4spd auto) does not have tall gearing at all...it is surprisingly short, but I dont remember the numbers.
GasSavers_James is offline   Reply With Quote
Basic Stats poorboymeyer Fuelly Web Support and Community News 2 09-22-2009 09:19 AM
