Moon Hub Caps & Wheel Skirts - Page 2 - Fuelly Forums
Old 11-30-2007, 09:07 PM   #11
Originally Posted by cfg83 View Post
The other ones you posted have little teeth that allow you to pop them in and out of your steel wheel, so they don't work with alloys.
are there any type of hubcaps that work w/ the civic VX alloy rims? (I like the look of the rims, but if I can squeeze out a little more FE, I don't mind covering them w/ moon hubcaps.
thanks!
first350 is offline   Reply With Quote
Old 11-30-2007, 10:26 PM   #12
GasSavers_Ryland's Avatar
thanks!
I think you would be better off getting some honda insight rims, they are going to be 14" insted of 13", but the stock insight tires are low rolling resistance 165/60 R14, or something like that, same width tires as stock VX tires, same weight rims, and they are semi-disk style wheels, where if you put disk hub caps on VX rims, you would still have the egg beater affect of the spokes on the back side of the wheel, because after all areodinamics is more then just what you can see.
Old 12-01-2007, 12:45 AM   #13
cfg83's Avatar
SL8Brick -
Originally Posted by SL8Brick View Post
I like these the best: http://www.speedwaymotors.com/p/4943...Moon-Disc.html
There's just something about the recessed lip on the others that I just don't care for.
I think you're URL is incomplete. Do you mean this one? :
http://www.speedwaymotors.com/pl/105...Moon-Disc.html
Optimal shape of wheel deflectors - convex/concave? MetroMPG Aerodynamics 8 01-01-2008 09:29 AM
Newbie from eastern PA! SL8Brick Introduce Yourself - New member Welcome 11 06-20-2007 08:29 PM
Hello GasSavers GasSavers_rGS Introduce Yourself - New member Welcome 1 06-10-2007 08:47 PM
where do I buy insulation? Matt Timion General Discussion (Off-Topic) 5 05-24-2006 08:40 PM
Dilemma concerning front sway bar on n600 Matt Timion General Maintenance and Repair 3 05-24-2006 10:37 AM
