Modifying your spark plugs - Page 3 - Fuelly Forums
Old 11-24-2005, 10:43 PM   #21
Compaq888's Avatar
I had my spark plugs gapped
I had my spark plugs gapped at .37 and the stock is .44
At .37 I didn't notice any improvement in fuel economy. It was all the same.
Old 11-25-2005, 12:12 AM   #22
I had previously done a
I had previously done a little research into this...if I wasn't running iridiums in 2 of my 3 cars, I would give it a try.
First off, a gap that is too small means that the spark duration will be very quick and the spark will be thin and weak. If the gap is set too large, the ignition system will not manage a spark and a misfire will occur.
From what I understand, sidegapping maintains a decent gap but allows more mixture-to-spark exposure area.
Team sidegapping up with indexing and its supposed to provide a modest improvement in power and mpg.
GasSavers_davens is offline   Reply With Quote
Old 11-25-2005, 06:41 AM   #23
FE nut
diamondlarry's Avatar
I think if a gap is unreasonably small there could be problems. Although, I've heard that some racers set gaps at .010 or so for extra power. I wouldn't do this in a daily driver type car. The theory is that with a smaller gap it will take less voltage to bridge the gap which means the current will be higher thereby producing a hotter spark. The spark may be smaller but it will be stronger.
2007 Prius,
Team Slow Burn
Old 11-28-2005, 05:51 AM   #24
Moderator
GasSavers_DaX's Avatar
On my turbo LS I had my
On my turbo LS I had my plugs gapped at .028"
I couldn't imagine going under about .020"
Old 12-09-2005, 06:55 PM   #25
Plasma physics is the kind
Plasma physics is the kind of thing that makes super computers worth thier money. Below the speed of sound the air can disperse the heat of air or an object moving through it (wind chill factor) above the speed of sound, the moving object(s) continue to heat up as the speed increases because the air can not disipate the heat as fast as the friction of the object moving through it creates it. Within reason this limits the speed of the propigating burn within a cylinder to the speed of sound(a ping). I believe that the same kind of thing can be formed at low speeds when the air becomes superheated during an ignition(thermal limit is reached). The shape of the plasma cloud is key to it's ability to correctly burn the fuel. This is the idea behind BOSCH 4s, and those new Diamond Fire plugs. My guess is that since the air in a cylinder is moving so fast, and is so inconsistent in composition, that it's best at low RPMS for the air to be ignited several times. This is why the ignition modules on the market offer up to 25 sparks per stroke at low RPMs. Is it was better to have a single spark last the duration of the cylinder's power stroke, or have several ignitions per power stroke. Will one long spark produce a helpful plasma cloud, or just a fuzzy burn? Do I buy a $20 lottery ticket or 20 $1 tickets?
CruiseControl is offline   Reply With Quote
Old 12-15-2005, 08:14 PM   #26
Read an article at another
Read an article at another gas savers site, and they said that by decreasing the gap, the spark voltage was lowered and the amperage increased. This increased the temperature of the spark plug, and that this was what ingnited the fuel, and not the spark. I'm not sure about the ignition part, but increasing the temperature of the spark plug, could cause the conductors to burn up faster, fuse it in the cylinder, or keep it above the ignition temperature of the fuel/air mixture. The later could cause an ignition during the exhaust stroke or intake stroke and a backfire through either the exhaust, or intake manifold. This probably wouldn't occur until the plugs had been run up to full operating temperature, or during some high speed or performance run, when they reached a peak operating temperature, and then suddenly your intake manifold exploded.
Old 01-01-2006, 09:56 PM   #27
Side Gapping
Here is another article on side gapping:
http://www.georgenitta.com/autotipssparkplugs.htm
Here is an explanation(?) of why a stronger spark is desirable:
http://www.msdignition.com/1helpmechoose.htm
GasSavers_JustMe is offline   Reply With Quote
Old 01-02-2006, 10:23 AM   #28
Thanks to the articles! I'll
Thanks to the articles! I'll be sure to read them thoroughly when I get back home.
Old 01-02-2006, 12:56 PM   #29
kickflipjr's Avatar
I will probally try
I will probally try side-gapping soon.
2008 EPA adjusted:
Old 01-02-2006, 01:00 PM   #30
It's finalized, the write up
It's finalized, the write up will be done tomorrow! Not that it takes much effort, but it'd be nice, I think.
Oregon-Washington: Winter gas ending, summer gas formula starting? 740dan General Fuel Topics 5 02-26-2013 10:17 PM
Ave MPG higher than best ever tonedepear Fuelly Web Support and Community News 2 06-04-2011 05:06 PM
miles between fuelup limit? drnknmnky13 Fuelly Web Support and Community News 6 09-14-2010 04:08 AM
feature requests ThatGuyDuncan Fuelly Web Support and Community News 4 09-18-2008 01:18 PM
Automatically add the 9/10ths of a penny on to the gas price Saiyaman156 Fuelly Web Support and Community News 1 08-10-2008 02:23 AM
