Modify O2 sensors - Fuelly Forums
Old 08-03-2006, 08:40 PM   #20
omgwtfbyobbq's Avatar
Lean burn improves combustion efficiency and torque, with the trade off being less hydrocarbon and more NOx pollution. Pumping losses are also reduced because more air is allowed in the combustion chamber and heat losses in the cylinder are reduced too, although I'm not sure how that works, probably has something to do with the size of a lean burn a/f charge.
Edit- Found something that says controlling swirl allows for stable combustion and better lean burn. Which makes sense, because hot spots in a cylinder could lead to pre-ignition, so controlling how the intake charge combusts (even combustion/heat distribution) is critical to being able to run lean without pre-ignition. Running an a/f ratio of 25:1 compared to 14.7:1 supposedly reduces fuel consumption by ~20% over the Japanese test cycle.
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
100,000 fuel-ups! reppact Fuelly Web Support and Community News 9 12-04-2008 08:19 AM
Hello GasSavers_scostanz Introduce Yourself - New member Welcome 7 06-25-2006 07:37 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
