Modification: Warm Air Intake - Page 4 - Fuelly Forums
Old 10-03-2005, 03:21 PM   #31
FE nut
diamondlarry's Avatar
The temperature gauge seems
The temperature gauge seems to run just under halfway. According to the Scanguage the temp runs right around 195 degrees and goes up slightly when sitting in traffic on a hot day. I can disconnect the EFIE fairly easy so I'll try it that way a couple of times.
2007 Prius,
Team Slow Burn
Old 10-03-2005, 04:15 PM   #32
FE nut
I just went for a couple of
I just went for a couple of runs. I disconnected the EFIE and got 56.3 mpg. I then reconnected the EFIE and went for another run. On the second run, I had to slow down for someone who was turning left in the middle of the run. On the second run I got 55.7 mpg.
2007 Prius,
Team Slow Burn
Old 10-03-2005, 04:39 PM   #33
Wow, that's a monstrous
Wow, that's a monstrous improvement for something so simple, cheap, and easy. I'm glad to see the EFIE didn't help much as I've kind of given up on the tuning function of my AFR gauge.
Flatland2D is offline   Reply With Quote
Old 10-03-2005, 04:47 PM   #34
Wow, I'm so down for trying
Wow, I'm so down for trying these. Thanks for running the tests so soon, haha, you're amazing. But wow, that rocks. My temp gauge is always at 1/3rd even in the 90 degree weather, so I think I can take this. And without a performance drop too, how amazing. Got any pictures of the set up?
Old 10-03-2005, 05:07 PM   #35
FE nut
Since it's already dark I'll
Since it's already dark I'll try to get some pictures after work tomorrow.
2007 Prius,
Team Slow Burn
Old 10-03-2005, 10:04 PM   #36
Matt Timion's Avatar
Re: Wow, I'm so down for trying
you might want to think about just getting a warmer thermostat for your car. Get one that opens up at 195 degrees and your engine will run warmer, and will probably give you better mileage.
Old 10-04-2005, 03:39 PM   #37
FE nut
Here is a link to the picture of my tep sensor mod. Thanks SVOboy for the hosting.
Larry
2007 Prius,
Team Slow Burn
Old 10-04-2005, 03:43 PM   #38
There's the picture. You've
<img src=http://www.filefarmer.com/cruisur/resistors.jpg>
There's the picture. You've just got to enclose that text in < and > to make it show up normally.
Old 10-04-2005, 05:44 PM   #39
SVOBoy wrote:There's the
<p><div class="quote-msg"><div class="quote-author">SVOBoy wrote:</div>There's the picture. You've just got to enclose that text in < and > to make it show up normally.</div></p>
A better way to do it is to use the [img] tags.
[img]IMAGE URL GOES HERE[/img]
Old 10-04-2005, 06:40 PM   #40
Larry!
Yo, larry, where is the IAT on the saturn's? I'm going to hook up one of your resistor combo's for a friend to test it and I just wanna get an idea beforehand of where it is so I don't have to look too long (since I'd be doing it before school and all). Thanks.
Large Fuel Tank capacity JQL Fuelly Web Support and Community News 7 04-04-2010 03:52 AM
Synthetic motor oils and MPG TONYPR70 General Fuel Topics 13 01-06-2009 05:36 AM
