Miss matched tires - Fuelly Forums
Old 02-16-2007, 05:08 AM   #1
zpiloto's Avatar
Miss matched tires
I just notice that I have a miss matched set of tires. The fronts are 185/65/14 with max pressure of 35 psi and the rear are 185/60/14 with 44 psi max. I'm thinking that I need to switch that around and have the smaller higher psi tires in the front for aero and rolling resistance. I dought that there would be much difference but want to here the groups thoughts?
Old 02-16-2007, 05:14 AM   #2
omgwtfbyobbq's Avatar
I don't think it makes much of a difference economy wise, but I generally put the higher pressure tires in front since that's where most of the weight/wear is, and the lower pressure tires that I'm inflating to 15-20psi above sidewall go in back. More for safety than anything else.
Old 02-16-2007, 08:44 AM   #3
Since both the Kia and Toyota are small FWD with a forward weight bias, I'd put the deeper tread tires on the rear.
The greater weight on the front will reduce the hydroplaning tendency while the lighter rear will benefit from the deeper tread reducing the same tendency at that end.
If both sizes have about equally deep tread, then the smaller of the two pair on the front will drop the nose for marginally better aerodynamics. Only about 3/8 inch difference in axle height with the 185-60 ~ 65 sizes mentioned.
As a benefit in your case the smaller ones for the front have a higher max pressure rating.
Old 02-16-2007, 10:04 AM   #4
Have you factored in the slight gearing advantage with the taller tires on front?
Never any simple answers, eh?
Old 02-16-2007, 12:40 PM   #5
zpiloto's Avatar
Kind of though of that but could not figure out if it really matters if it's on the front or the back? I guess the only way to know for sure is test and that too much of a hassle with the make shift wheel skirts. I've got some moon discs coming I'll swap um around after that. I think I want the higher pressure in the front.
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 01:12 AM
More fun on FUELLY brytrkr1 Fuelly Web Support and Community News 3 12-06-2009 10:41 PM
Newb FAQ Red Tick General Fuel Topics 4 06-15-2006 01:34 PM
MetroXFi changed his name! SVOboy General Discussion (Off-Topic) 26 04-09-2006 06:38 PM
