Milage keeps decreasing with every tank... - Page 4 - Fuelly Forums
Old 10-22-2007, 02:12 PM   #31
GasSavers_Minger's Avatar
I know, but I can't get a minute out of it - theres only like three places where I can do that (one pulling into work, about .7 of a mile, another down a hill to a light thats usually red, and one pulling into my neighborhood, which means I have to turn fast and the neighbors don't like it :P)
P.S. I must be a wierdo as I think just because a guy can afford to do something, doesn't mean he should. I can afford to buy 100 gallons of gas several times a month, pour it on the ground, light it (or not)... but I don't think I should.
GasSavers_Minger is offline   Reply With Quote
Old 10-22-2007, 02:15 PM   #32
Well then, guess you'll have to bike.
Old 10-22-2007, 02:16 PM   #33
What you see in neutral is the minimum fuel it takes to keep the engine turning over at idle - end in gear it doesn't take any fuel to keep it turning over becuae the engine is being turned over by the transmission - wheels - energy in the car . . . thus saving even more fuel but slowing you down a little. So coast in neutral when you do not want to slow down and coast in gear when you want to slow down or need to limit your down hill speed. Cool that it can figure out that the injectors are shutdown when in gear - my Scion doesn't do that and I end up with lower than actual MPG readings whenI engine brake a lot.
Old 10-22-2007, 02:19 PM   #34
Cool, never thought about that.
Its just that the first time I saw 9999 i was like 'LOLWTF?'
Old 10-22-2007, 03:50 PM   #35
1993CivicVX's Avatar
My VX goes faster in gear than in neutral when coasting! Does it also use less fuel in gear!?
three stripes the charm!
Old 10-22-2007, 04:00 PM   #36
No, it only uses no fuel when engine braking.
Old 10-22-2007, 04:07 PM   #37
Wait, in gear it's using no fuel? For real? I've been wasting fuel this whole time?!?!?!?!?
Let me get this straight. I put it in gear, but don't touch the gas pedal. I'm using no fuel?!?
Old 10-22-2007, 04:09 PM   #38
Only if you're engine braking...if you're at a low enough rpm and not engine braking the car will be injecting fuel.
Buy a freaking supermid already.
Old 10-22-2007, 04:22 PM   #39
Hmm... yeah, tires first. Then maybe supermid. You'll have to install it for me tho.
Old 10-22-2007, 06:00 PM   #40
On your car, when your throttle is closed (foot off of the pedal) and the engine rpm is above about 1500 rpm, the ecu doesn't enable the injectors and it doesn't use any fuel. When your engine rpm gets to about 1500, then the injectors are used to bring the engine to a smooth idle.
CRX HF Transmission Rebuild GasSavers_DaX General Fuel Topics 35 09-15-2010 04:37 AM
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 02:18 PM
Car Heaven Canadian program. Emissions minic6 General Fuel Topics 43 06-11-2007 06:58 AM
Innovate LC-1 WB O2 sensor Installed CoyoteX General Fuel Topics 12 04-15-2007 05:26 PM
Just fired up the swamp cooler Matt Timion General Discussion (Off-Topic) 13 08-04-2006 06:43 AM
