I guess when you run a car lean you get more NOx than normal so it might not be great for emissions but then again I still have not gotten around to putting a catalytic converter back on the exhaust so I guess it really doesn't change much coming out of the tailpipe.
I figure cars around here make no difference to the area's pollution since you have no idea what kind of mess they make with the emissions from coal mines around here. If you have a carbon monoxide detector in your house it will go off randomly if you are downwind of a mine. Mines around here are really bad for your health.
I am using the LC-1 wideband it is a pretty nice little device. Well worth the money they want for it. I would like to take my car and dyno tune it one day and get the fuel maps dialed in perfectly but with the wideband on the car it really isn't as important to dyno tune a car as much as it used to be. I figure the car is putting out less emissions now than it was since the car is running closer to ideal. But without finding a shop with a tailpipe sniffer around here there is really no way of knowing.
Also if anyone has downloaded the map I put on the car notice I put the fuel cutoff while coasting down to 1250rpm So pretty much any time I let off the gas it cuts the injectors
There is a lot of stuff you can tweak to help mileage so once I get some miles on this setup it might be pretty impressive.
