Maximum tire pressure - Fuelly Forums
Old 09-26-2007, 10:51 AM   #1
holypaulie's Avatar
Question Maximum tire pressure
Old 09-26-2007, 08:29 PM   #2
Elaborate??
What does it say on the side of your tires? Probably 35 or 44.
You can go over that, they wont pop, but your ride will be harsher and the wear wont be as even.
My metro is 45 in 35 tires (rough) and my mustang is 50 in 51 tires (rough as hell)...
Old 09-26-2007, 08:42 PM   #3
1993CivicVX's Avatar
My fronts are 35 and my rears are 44. So I put my fronts to 43 and my rears to 48. I am told bad to have rears higher than fronts as the rear of the car has little weight and could get squirrely. But... what am I gonna do?
three stripes the charm!
Old 09-26-2007, 10:17 PM   #4
cfg83's Avatar
theclencher -
why do you insist on running the rears at higher pressure???
Do you think they should be the same, i.e. 43 PSI for his purposes?
I am super cautious. With 35 PSI max and a normally low/unloaded car, I would probably go up to 40. But, since others have been running 60 PSI in 44 rated max tires, I think 43 PSI is ok.
Here's yet another site on tYres :
The wheel and tyre Bible
http://www.carbibles.com/tyre_bible.html
electric l/100km MJ/km Efried Fuelly Web Support and Community News 2 08-25-2008 08:41 AM
Feature suggestion: website badges acheslow Fuelly Web Support and Community News 4 08-11-2008 03:19 AM
Newby here diaperden General Fuel Topics 4 06-19-2007 01:54 PM
Questions about EOC and automatic transmissions txe5502 Transmissions and Running Gear 14 06-08-2007 02:53 PM
high compression thought? chromejunks General Fuel Topics 14 11-28-2005 08:48 AM
