math to calculate mpg from injector pulse width - Page 2 - Fuelly Forums
Old 05-15-2008, 10:56 AM   #11
Whoops, come to think of it, the vacuum bias on the FPR really only compensates for the manifold vacuum the injector is spraying into.
Old 05-15-2008, 01:34 PM   #12
EH3
EH3's Avatar
correct. there's nothing electronic about it. it's just a spring loaded diaphram.
obviously the problem is that at high vacuum the fuel pressure is about 8psi lower than at ambient/low vacuum. that number even varies between honda engines with DOHC VTEC typically having fuel pressure at 50psi ambient versus ~42 for SOHC and non-VTEC engines
EH3 is offline   Reply With Quote
Old 05-15-2008, 01:47 PM   #13
Yeah there's 8psi less push, but 8psi more suck on the other side of the injector.
Old 05-15-2008, 01:50 PM   #14
Correct. But, since the manifold is 8psi lower (due to the vacuum) the amount of fuel flowing per % of on time is the SAME as if you were at WOT and there was no vacuum (and higher fuel pressure to match!)
Should be able to calculate fuel consumption soley based on the injector's duty cycle and rated flow at your operating nominal fuel pressure. The catch is, some of the 'on' time is taken up by the amount of time it takes to open (and close) the injector, during which time it's not flowing at 100%. There should be some math to correct for that effect, which is primarily noticed at very low duty cycles...
Dalez0r is offline   Reply With Quote
Old 05-15-2008, 05:38 PM   #15
dalezor: "Should be able to calculate fuel consumption soley based on the injector's duty cycle and rated flow at your operating nominal fuel pressure."
That idea makes sense to me, and it seems like a very good way to calculate fuel consumption.
There seem to be a bunch of products/systems that do it in a way that seems to be inferior: they calculate fuel use indirectly, based on airflow. I think they do it this way because they're relying on OBD2, and OBD2 delivers airflow data, but not injector data (I'm talking about generic OBD2; the statement I made doesn't apply to certain specific manufacturers). SG is an important example of a product that seems to have this problem (although it has many other strengths).
Anyway, does anyone know of any existing product/system that does it the 'right' way? I'm a little surprised that I'm having a hard time finding such a thing.
Of course one example of a project doing it the 'right' way (in this regard) is this one:
http://forum.ecomodder.com/forumdisp...mputer-26.html
Any other examples?
Old 05-15-2008, 05:45 PM   #16
The SuperMID, of course. I forgot to mention that one (as an example of a product that watches the injectors).
Any others?
Fuelly API, Remote Update hufman Fuelly Web Support and Community News 6 11-26-2017 11:28 AM
Not very precise mpg calculation larjerr Fuelly Web Support and Community News 4 08-20-2012 02:03 AM
Keeping my distance in traffic khurt General Fuel Topics 8 09-07-2008 04:23 AM
Electrical power and cars. DracoFelis Automotive News, Articles and Products 2 09-16-2006 02:31 PM
Honda TPS Sensors - $15/ea Matt Timion For Sale 7 06-27-2006 12:05 PM
