Manual tranmission gear upgrade? - Fuelly Forums
Old 02-29-2012, 10:06 PM   #1
I have a 97 civic ex w/manual transmission. Been reading that the hx transmission has a better final drive. What is the best way to convert to the better gears. Changing out the final drive or changing out the whole transmission?
biddaum42 is offline   Reply With Quote
Old 03-01-2012, 04:22 AM   #2
GasSavers_Erik's Avatar
Re: Manual tranmission gear upgrade?
Assuming that there were no differences in electrical connectors etc., it would be easier to just swap out the whole transmission.
Old 03-01-2012, 08:54 PM   #3
I understand the hx transmission has a better final drive. But the EX has bigger bearings for the final drive.
What years of transmissions can i use for the better gears. And out of which models. And will the gears swap into the Ex transmission to keep the better bearings.
Next is there a better flywheel and clutch assembly to use then stock?
Old 03-02-2012, 06:20 AM   #4
Here is a link I found with google:
http://www.knology.net/jediklc/gearratiosdseries.htm
I'm not sure about compatibility of internals. Maybe you can find a website dedicated to 5th and 6th generation civics and ask there.
Old 03-02-2012, 07:09 AM   #5
d-series.org has more information about your transmission than you could ever want or need.
The cost to benefit ratio of gear swapping probably isn't worth your time. The car you have now is capable of 40mpg's or better with good driving technique and it isn't a complete slug.
A full transmission swap is far easier than gear swapping.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
MPG loss due to supercharger bobc455 General Fuel Topics 18 09-20-2010 01:23 AM
canola rollaz DRW General Discussion (Off-Topic) 5 10-24-2007 04:58 PM
VX rear wheel hubs -anyone replaced theirs? jadziasman General Maintenance and Repair 13 06-15-2007 12:16 PM
TPS Will a 88 Civic DPFI TPS Work on a 92-95 D15z1 8Civic8 General Maintenance and Repair 2 11-09-2006 11:12 PM
vegpowered systems GasSavers_Diemaster Vegetable Oil and BioDiesel 2 09-08-2005 05:53 PM
