Managing EGR for MPG - Fuelly Forums
Old 10-20-2006, 09:15 PM   #36
DRW
Managing EGR- What to Do?
Thanks to the inspiration I get from this site, I dug into the ECU disassembly for my car and found an interesting section. The problem is, I'm not sure what to do with it? Here's a copy/paste, have a look:
; EGR solenoid duty cycle
; as a function of rpm(column) and airVolume(row)
;Value of $00 to $80 will produce 0 to 100% duty cycle
t_egrDutyFact
#ifdef E931
RPM 500 1000 1500 2000 2500 3000 3500 4000
Load
1. $10 .byte $00, $00, $00, $00, $00, $00, $00, $00
2. $20 .byte $00, $00, $00, $5b, $56, $4c, $4d, $00
3. $30 .byte $00, $00, $00, $5b, $56, $4c, $4d, $00
4. $40 .byte $00, $00, $00, $5b, $56, $60, $5c, $00
5. $50 .byte $00, $00, $60, $76, $6c, $5f, $5b, $00
6. $60 .byte $80, $80, $80, $7d, $6e, $5f, $60, $00
7. $70 .byte $80, $80, $80, $80, $76, $68, $61, $00
8. $80 .byte $80, $80, $80, $80, $80, $60, $61, $00
9. $90 .byte $00, $80, $80, $80, $80, $78, $6e, $00
; EGR solenoid duty cycle as a function of ECT
; Value of $00 to $80 will produce
; 0 to 100% duty cycle
t_egrDuty .byte $80, $80, $5b, $4f, $00, $00, $00, $00
ECT degreesF- 186 176 125 95 69 46 19 3 ->
As you can see, this is where EGR is handled. I know where this section is located in the code, so I can change any of the bytes to adjust the duty cycle.
I've searched for good articles about EGR, but mostly I seem to find basic info about what it does. As you might have guessed from the disassembly, I'm looking for reasons why EGR might be useful or harmful to FE when increased/decreased as the engine sees different loads and different temperatures. If needed I can also make adjustments to the fuel and/or ignition timing maps to optimize the EGR effect. But like I said, where do I start? If anyone out there has run across some detailed tech info about EGR, let me know. I'll keep searching too. If the code isn't clear, just ask.
Thanks!
Dave W.
Dave W.
Program not work.. while entering price in Thai Bhat ihightower Fuelly Web Support and Community News 1 08-27-2010 01:41 AM
Scan gauge Tank MPH Avg zpiloto General Fuel Topics 5 03-22-2006 02:32 PM
aftermarket mirror ?= frontal area reduction thisisntjared General Fuel Topics 11 03-21-2006 07:23 PM
