LRR tires - Fuelly Forums
Old 03-16-2008, 07:04 PM   #1
LRR tires
Looking for a set of LRR tires for my vx, what are my options? I have ONE 13" michelin proxima RR from the EV1's that i found on ebay a few months ago, chances are prety slim that I will find another.
siray13 is offline   Reply With Quote
Old 03-16-2008, 08:32 PM   #2
I bought a set of VX rims a month ago from user XFi. You can read the thread:
http://www.gassavers.org/showthread....ight=VX+wheels
The tires on them are LRR Kumho 795s. 155/80/R13 matches my stock Civic tire height almost perfectly.
Can't comment on them yet. I'll drive on them in a few weeks when Spring finally arrives for good in upstate NY.
You might also look at this archived thread:
http://rds.yahoo.com/_ylt=A0oGkmIP5N...es/t-2662.html
(or just Google "LRR VX")
Regards,
Bill
Nrggeek is offline   Reply With Quote
Old 03-17-2008, 02:46 PM   #3
my next tires(LRR) will be Somitomo HTR200. they are rated very well along with more expensive Goodrich and Michelin. in fact,they are rated better than most of the tires that are priced higher!
tirerack has them.
Old 03-17-2008, 05:05 PM   #4
what about the bridgestone potenza re92? it's a 165/65-13 it's the same kinda that is on the 14" insight. Any success or complaints about this tire?
Old 03-18-2008, 02:42 PM   #5
according to tire testing on tirerack, bridgestone tires do not score very well in general.
Old 03-18-2008, 03:04 PM   #6
I've heard bad things about the RE92, but only that tire. I've driven on a set of Bridgestone Eager tires and loved the traction on all surfaces (wet/dry/light snow). The RE960AS is one of the best rated tires on tire-rack.
I wouldn't judge brigestone by one poorly rated tire model.
For RR test info check this link out:
http://greenseal.org/resources/repor...resistance.pdf
samandw is offline   Reply With Quote
Old 03-18-2008, 04:50 PM   #7
my observation was based on econo car tires in general which is peritinent to this thread. 3 tires made by bridgestone are offered for my application (175 or 185/65/14). NONE rated particularly well.
certainly not ALL of their tires rate this way. some of their larger, performance tires do rate very well.
one other observation...
it seems for the price, better deals can be had for almost any application over what bridgestone charges.
Old 03-19-2008, 06:12 AM   #8
s2man's Avatar
I've been pleased with my General Ameri G4S, made by Continental Tires. They had the second lowest CRR in this report, in the 2002 data. It also contains 2005 data. I contacted Continental and verified it's the same tire, they just changed the brand name to General.
Roll on,
S2man
s2man is offline   Reply With Quote
Old 03-19-2008, 08:47 AM   #9
Thanks for that link s2man...
Wow! holy freakin' confusing batman! There's some offroad tires with lower RR than touring radials. There's some manufacturers where the 70 profile does better than the 65, then there's some where the 65 does better than the 70 or 75. Looks like a crapshoot, you might hear that a particular tire has a LRR but in the tire size you need, something different might do better!
Old 03-19-2008, 07:58 PM   #10
I have RE 92's fitted to my car as standard equipment.
205/65-15.
To sum up:
Noisy. Much more so than the Michelins on my previous Commodore. On a coarse mix surface they drown out the CD. Reasonably quiet on a smooth surface which is hardly a compliment.
Hard. Bridge joiners and freeway cats eyes are to be avoided if possible. Pressures are as per the tyre plate at 250.
70 000 on the car and virtually worn out. The previous Michelins lasted well past 100 000.
Handling is OK but not brilliant. NOT confidence inspiring by any means.
Others may find they are different on other cars but that is my experience.
Pete.
GasSavers_Pete is offline   Reply With Quote
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 02:12 AM
DIY vortex generators... ZugyNA Experiments, Modifications and DIY 5 08-27-2010 04:14 AM
Windows vs. A/C DHA General Fuel Topics 7 11-19-2009 07:57 AM
Basic Stats poorboymeyer Fuelly Web Support and Community News 2 09-22-2009 09:19 AM
Performance Underdrive Pulleys? cfg83 General Maintenance and Repair 10 09-08-2007 09:04 PM
