Lowering For FE - Page 2 - Fuelly Forums
Old 12-09-2010, 06:01 PM   #11
Send a message via Yahoo to Roadking41a
Re: Lowering For FE
Axle flip or hanger flip?
Axle flip. I can get the U bolts and spring perches reasonable along with a friend who can help cut the frame a little and weld in plate steel.
Roadking41a is offline   Reply With Quote
Old 12-10-2010, 03:42 AM   #12
Re: Lowering For FE
Nice. That's going to be a LOT of lowering all at once. Do you have clearance for the tires? Do you have a plan for lowering the front too so you're not "sitting Cali" with too much lean?
Old 12-10-2010, 08:47 AM   #13
Re: Lowering For FE
Yeah all the way around. The fun part is the bushings for camber alignment.
Old 12-10-2010, 01:02 PM   #14
Re: Lowering For FE
If its cheap and easy go for it. If it was me id be looking for a 5sp and a 2.73 equiped rear end. shoudnt be too much money for both. If you do decide to lower make sure you take a pretty good gas log so we can all see the effects.
kit352 is offline   Reply With Quote
Old 12-10-2010, 03:07 PM   #15
Re: Lowering For FE
Will do it will take time to get everything together.
One Really Neat Lady shatto General Discussion (Off-Topic) 0 06-23-2009 07:45 PM
85 Tercel 4WD Wagon - Where to start? Snax Aerodynamics 16 11-15-2007 03:40 AM
LA Alternative Car Show Pix ... cfg83 General Discussion (Off-Topic) 8 10-11-2007 05:08 PM
Pump Police tomauto General Discussion (Off-Topic) 1 11-17-2006 02:50 PM
Georgia Interstates are getting wide....VERY wide GasSavers_DaX General Discussion (Off-Topic) 4 03-10-2006 11:00 PM
