Low Rolling Resistance Tires - Page 2 - Fuelly Forums
Old 11-19-2005, 03:53 AM   #11
Compaq888's Avatar
I don't know about you but I
I don't know about you but I pumped up my tires a little more and it gives me 3mpg more. I don't know if mine are low resistence tires but they are Kumho all season 716's
Old 11-19-2005, 07:30 AM   #12
Yours won't be LRRs, compaq,
Yours won't be LRRs, compaq, but 3 mpg, that's a damn good deal. I would go with whatev the insights use, because people pump those up to 55 psi and get good results out of them.
Old 11-19-2005, 09:45 AM   #13
45 PSI Always
I've always run 45 PSI and haven't had any unusual wear in the middle and can still take the exit ramps at 60. I'm thinking of getting either the Insight or Civic Hybrid tires when the current ones wear out (which is soon, and snow is on its way) - but I'm sure handling will suffer :-(
Old 11-19-2005, 05:06 PM   #14
Compaq888's Avatar
Does the new 2006 civic
Does the new 2006 civic hybrid have low resistent tires?
Old 11-19-2005, 05:13 PM   #15
They ought to, I'm not
They ought to, I'm not entirely sure though.
Old 11-19-2005, 05:21 PM   #16
Compaq888's Avatar
ok, I just want to know for
ok, I just want to know for sure because I got mine for $279 installed and balanced and they handle way better then my previous tires.
I just don't see the point in buying special tires for a lot more and getting only 1-2mpg.
Old 11-19-2005, 05:22 PM   #17
The 2006 civic hybrid uses
The 2006 civic hybrid uses kumhos?
Old 11-19-2005, 05:39 PM   #18
Compaq888's Avatar
no, lol. I do. I do know
no, lol. I do.
I do know they are the same size as my car. 195/65/15
I stopped using that size. I now use 205/60/15
Old 11-19-2005, 05:53 PM   #19
Ah, gotcha. Bigger tires
Ah, gotcha. Bigger tires will also cut down on your mpg by the way, especially if you get 21 chrome spinners. --_^
Old 11-23-2005, 02:56 PM   #20
"Unsprung Weight"
Reducing the diameter but also, based on racing principles, the lighter the weight of the rim has a huge impact on not only the handling, but in fuel economy (The "Unsprung Weight" Principle). It takes less energy to get them going and less to stop (like a flywheel). Unfortunately, lightweight rims tend to come in larger sizes (unless you source them from a hybrid).
-RH77
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 02:12 AM
Data/Chart Discrepancy PTH Fuelly Web Support and Community News 3 07-02-2010 08:14 AM
Basic Stats poorboymeyer Fuelly Web Support and Community News 2 09-22-2009 09:19 AM
Graphs itsastationwagon Fuelly Web Support and Community News 2 08-13-2008 03:04 PM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 08:27 AM
