Low-ri-da Metro? - Fuelly Forums
Old 08-04-2007, 10:18 PM   #1
Low-ri-da Metro?
Lol, well, not quite, but I've been considering lowering the ride height of my metro. Anyone have experience with this? What kind aerodynamic gains could be expected? Handling? Perhaps this would cut out some of my body roll too?
I have progressive springs in back (NO cutting) and struts up front, so that leaves clamps as my only option right? Are they an ok option?
The Metro has always sat high, but I've lightened the car up nearly 100 pounds and now its real high, especially in the back.
Thanks
Nic
Old 08-04-2007, 10:52 PM   #2
cfg83's Avatar
baddog671 -
Thanks
Nic
Other people have written that clamps are good for testing, but not long term use. Some people have even used rope instead of clamps!
Old 08-05-2007, 04:30 AM   #3
skewbe's Avatar
I'll be cutting my coils pretty soon, don't see why that shouldn't be an option.
http://www.teamswift.net/viewtopic.php?t=7070
http://www.teamswift.net/viewtopic.php?t=11403
http://www.teamswift.net/viewtopic.php?t=26246
Standard Disclaimer
Old 08-05-2007, 05:28 AM   #4
minic6's Avatar
Clamps will eventually wear through the coils, it takes a while. Here is the thread were my springs were cut. I have been very happy with the results. Takes a day to do, with the correct spring tools. There is a method of doing them in the car, but when I tried to many things like bearings fell out! It worked better for me to remove them. Follow down past the tire size change and you'll find the pics. of the cut springs.
http://www.gassavers.org/showthread.php?t=3550
minic6 is offline   Reply With Quote
Old 08-05-2007, 01:29 PM   #5
Originally Posted by skewbe View Post
Correct me if I'm wrong, but I thought you couldn't cut progressive rated springs....
Old 08-05-2007, 01:44 PM   #6
minic6's Avatar
I'm no suspension expert, but the mod was done a couple of months ago with no ill effects. Others on the site have been driving theirs much longer than I, any input by those of you who inspired me?
Old 08-05-2007, 02:08 PM   #7
I'm currently redoing the suspension on my 67 so let me use that as an example, to help clear my head if I'm making a mistake here. On my 67, the springs are essentially straight, no variences. On my Metro, the springs are not the same. They 'taper' in towards the bottom of the spring till they mate with the control arms at the designated spot. If you were to cut a coil off of this, that would increase the diameter of the mating coil and not allow it to fit into the spot it is supposed to go into.
The 67 wouldn't have this problem since it is the same diameter the entire length. I was told that the tapered ones are progressive rated and cant be cut.
And you can't cut a strut anyways, correct?
Old 08-05-2007, 02:11 PM   #8
minic6's Avatar
The rear spring as the pic shows was one whole coil it was the easy one. The fronts were cut at a half a coil at both ends, because as you stated they would not fit correctly other wise.
Old 08-05-2007, 07:22 PM   #9
I'm usually not a fan of cut coils--but I am a fan of lowered cars and have lowered every car I've owned since high school, forty five years ago. After-market lowering springs are a better choice. Intrax makes Geo coils and I'd guess others do too. Cut coils, while less expensive, are not as predictable as good-quality custom coils. My own choice is Eibach if they make them. The quality's there and the ride has always been good.
Having said that, I plan to put BellTech drop ball joints on my Colorado. They preserve front suspension travel that's lost in any spring solution.
GasSavers_Graeme is offline   Reply With Quote
Old 08-05-2007, 08:24 PM   #10
Hmm, well, I don't really want to end up spending big bucks for new coils and having to take the time to replace them. I was looking for a quick fix
Stupid Idea landspeed General Fuel Topics 5 02-28-2007 09:40 PM
Cardboard box + duct tape = LxMike Aerodynamics 18 11-18-2006 11:53 AM
p07 ECU $15 Matt Timion For Sale 4 08-27-2006 12:25 PM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 04:22 PM
