loremo 156MPG car - Page 2 - Fuelly Forums
Old 03-19-2007, 07:56 PM   #11
Mike T's Avatar
Originally Posted by Sludgy View Post
The Loremo could come to America if it uses modern gas engine technology. A one cylinder, long stroke, four valve VVT engine with direct fuel injection displacing 400 - 500 cc would make about 40 HP, and it would smoke the Loremo's puny and heavy diesel engines.
The complete smart fortwo cdi 800 cc common rail diesel engine weighs 69 kg, or about 150 lbs. It's a fair whack smoother than a large displacement one lunger would be too.....not to mention having very favourable torque characteristics (peak of 74 lbs*ft at 1800-2800 rpm).
The smart's gasoline engine is 10 kg lighter, and is also an inline three; it would be an easy transplant by the Loremo company, if they ever actually do build + sell a car. Plus they make 84 HP in turbocharged form, which would make the car a rocket!
2008 Mercedes-Benz B 200
Mike T is offline   Reply With Quote
Old 03-19-2007, 08:38 PM   #12
The Toecutter's Avatar
**** a diesel Loremo. This thing would go about 100 miles per charge at 70 mph on 800 pounds of lead acid batteries. Replace with same weight of NiMH or NiCd and range would be about 250 miles; with same weight in Li Ion that range would be about 500 miles.
If this car ever gets produced, it is a realistic route to a $20k EV with 0-60 mph < 7 seconds, > 150 miles range, > 120 mph top speed.
Old 03-20-2007, 05:17 AM   #13
The Loremo could use a one lunger engine and get better economy. I don't know why people are so opposed to one-lungers. I drive a Honda X650L. It has a balance shaft, and doesn't vibrate as much as one would think.
There are millions of one-lunger Japanese dirt bikes out there. Unfortunately, they're all tuned for high end power, not FE. I wish SOMEONE would make a one cylinder, long stroke 400 cc street motorcycle with with VVT and fuel injection.
Any of the Japanese manufacturers could do it. Hell, even stodgy old Harley Davison has switched to fuel injection.
Old 03-20-2007, 10:30 AM   #14
Team GasMisers5!
landspeed's Avatar
Originally Posted by lunarhighway View Post
the cars structure and chassis are going to produce a natural flat underside. so it's basically i big duct from the front to the back... i remember someone here was thinking about ducting high pressure air from the front to the rear to reduce the wake... this might be just that...
That was me (or at least I did post something like that) http://www.gassavers.org/showthread....&highlight=air
At the time I posted that I designed a car that I would like to build one day, using aero principles, and it looks very similiar to this (except a bit more radical in aero design). That is why I would love to get this car
Hypomiler
Old 03-20-2007, 10:35 AM   #15
Team GasMisers5!
landspeed's Avatar
Theres no way that this car will meet the latest USEPA smoke and NOx emissions regulations, so there is no chance it will come to the USA.
The annoying thing is, if this car puts out double the NOx emissions (in parts per million) as a Hummer, then won't be allowed. However, the Hummer will actually put out more (in grams / mile etc), although have less in terms of parts per million.
Hypomiler
Old 03-20-2007, 02:26 PM   #16
lunarhighway's Avatar
what would be the problem here? i gather from what you say that the regulations use relative rather than absolute criteria which would favor bigger engines? is this the reason why the smart had to get a different engine in the US as well? perhaps they could fit that one in....
All i know about NOx is that it's produced more when an engine burns leaner, is that correct?
at any rate the beauty of the car seems to be that it relies on aero and weight reduction rather to be build around one "yet to be invented" magical power source...
Old 03-20-2007, 03:37 PM   #17
If only it wasn't burning that dirty diesel crap. Ever look at the charts for the VW TDI's? They get 50 mpg, but their emissions are worse than most SUV emissions!
Old 03-20-2007, 04:02 PM   #18
That's what B100 is for. Will cut all emissions except NOx by about 90% compared to petroleum diesel, and NOx will increase about 5-10%.
Old 10-25-2007, 07:46 AM   #19
BamZipPow's Avatar
Send a message via AIM to BamZipPow
New link...
BamZipPow is offline   Reply With Quote
Old 10-25-2007, 09:39 AM   #20
garyhgaryh's Avatar
Looks like consumption went up to 2.0L/100km. How much mpg is that?
Little weight – easy to move. Less weight – easier to move.
This simple physical principle, which we can experience with our own bodies on a daily basis, specially applies to sports cars. By ruthlessly exploiting this principle, thus reducing weight and air resistance, we succeeded in cutting the Loremo’s fuel consumption to just 2.0l/100km.
garyhgaryh is offline   Reply With Quote
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 02:01 PM
DIY: Wire Tuck!!! SVOboy Experiments, Modifications and DIY 11 09-21-2006 04:17 AM
