Look at this schematic for my O2 sensors... - Fuelly Forums
Old 06-04-2008, 04:24 AM   #1
Which wire is the computer signal wire?
Want to know which to cut into to inject voltage from EFIE
This is a Mits 2004 Galant ES
Thanks for any help.
joeventura is offline   Reply With Quote
Old 06-04-2008, 04:27 AM   #2
Here is a close up, looks like the pic quality is bad:
Old 06-04-2008, 04:42 AM   #3
The two plates with the arrow look like it's the "variable cell" and that side is shielded, so I'd figure the white, pink, green and yellow wires were the outputs. The other side must be the heater.
Old 06-04-2008, 05:53 AM   #4
Ok I will shave into one of those and see what the meter shows.
If anyone else has any feedback, I would love to hear it.
and thanks RoadWarrior!!
Old 06-04-2008, 05:54 AM   #5
Is it surprising that a Mits 04 has 4 O2 sensors before the Cat?
I was very surprised to learn I would need to dual EFIEs (ugh)
Old 06-04-2008, 07:17 AM   #6
Well it allows better control of fuelling on a per cylinder basis... 1 and 4 on most 4cyls are reckoned to tend to run richer than 2 and 3, so it would solve that issue. Also if one cylinder goes lean due to a bit of dirt or varnish in an injector it's not going to hose 20% more fuel in the other three cylinders trying to compensate.
Old 06-04-2008, 08:55 AM   #7
This is a 3.8 liter engine (6 cylinders), so it actually has 2 pre-cat O2 sensors and 2 post-cat sensors (catalyst monitors) for each bank of cylinders...I was looking on mitchel on demand and it doesn't really get in to what wire goes where, but if you're going to tap i, i would go with the 2 front o2's and i would get an automotive dvom and check voltages with key on engine off. the 12v + would be for the heater circuit...
GasSavers_peter is offline   Reply With Quote
Old 06-04-2008, 12:56 PM   #8
My car and the schematic I provided is from the 2.7 L 4 cyl engine actually.
Are you saying for purposes of applying an EFIE I should go with the front two ONLY?
Thanks
Old 06-04-2008, 04:34 PM   #9
You were correct, checked it this evening and that wire was fluxing between .1 and .9 volts. Very cool
Anyone have an opinion on whether I need a DUAL EFIE for the lower (rear)
O2 sensors?
Thanks to all!!
Tail pipe restrictor test GasSavers_Erik Experiments, Modifications and DIY 36 06-14-2008 06:09 PM
Any tips for ignition cut-off switch? slimreynolds General Fuel Topics 3 09-03-2007 08:01 AM
New Japanese Crap Request Thread SVOboy General Discussion (Off-Topic) 10 07-01-2007 03:34 PM
Hello GasSavers_scostanz Introduce Yourself - New member Welcome 7 06-25-2006 07:37 PM
Air Dam SVOboy General Fuel Topics 23 11-12-2005 05:45 PM
