 GasSavers_mczarski What about 06-21-2007, 08:10 PM
06-10-2007, 01:08 PM
gas mileage indicator
can you these for any make/model?
i have a 97 ford taurus.
is it inaccurate to drive until youre on empty, refill completely, reset the trip odometer and divide the numbers?
i hope so, because i'm only getting about 18/mpg if not!
06-15-2007, 12:55 AM
I have a 1997 Mercury Sable (very similar car) and I get 18-20mpg city and 22-23mpg highway so...you're not wrong.
I recommend:
Amsoil Series2000 synthetic motor oil ($7/quart, one oil change per YEAR. Order online.)
Full tranny flush (learn how to disconnect the hoses to flush all 13 quarts instead of just 5)
PCV valve ($5), fuel filter ($7), spark plugs ($12 for six), air filter ($20).
The latter items are cheap enough that you can change them frequently (every year or so). PCV, fuel filter, and air filter are easy to change in 5mins with no tools. Spark plugs (aka a "tune up") is a bit more work, but can be done in ~1hour.
Also, a couple tanks of premium gas will clean out the engine.
05-11-2008, 11:23 PM
Why couldn't you just refill then start the trip counter? test at 1/4th 1/2 and 3/4ths empty?
My 96 volvo wagon burned out the fuel pump because I was on less than 1/4th tank religeously for...months.
Another gas saving tip is not mentioned here, and is completely obvious. Not so much gas saving actually as money saving, which is: gas stations almost always have cheapest gas on tuesday. Why? Think about it... you had an eventfull weakend, you forgot to get gas and you MUST get to work quick. They can charge you alot because you're unprepared. But this isn't true in all areas. Fill up tuesday, the comute rush is over, and no one is making plans to go many places. thursday through sunday night is the most expensive gas for the week, and you can bet your *** they will jack the price because you want to go have fun.
Also, if you have a indian reservation, or a nearby military exchange, it can sometimes be an incredible savings. Buy some large gas cans. I go to the indian reservation and get both my car and my 2 gas cans filled. Traveling to the gas station itself is a waste of gas too yknow.
Drive it like you stole it. Then go faster.
