list of gas saving tips from best to worst - Page 12 - Fuelly Forums
Old 06-11-2008, 06:24 PM   #111
Originally Posted by vizmon View Post
You may have seen the tips, but others may have not.
I'm no scientist, but I've learned elementary science in school to know that this guy is not talking nonsense.
Take it with a grain of salt if you like, just don't dismiss anything without even bothering to try it out.
snopes:
http://www.snopes.com/inboxer/household/gastips.asp
I've gotten that one on email about 15 times....
shupack is offline   Reply With Quote
Old 06-25-2008, 08:59 AM   #112
cyclone fuel saver
Has anyone done any definitive studies on the Cyclone (tornado) fuel saver?
does it really work or is it just hype?
TIA
hondaguydude is offline   Reply With Quote
Old 06-25-2008, 10:54 AM   #113
No, it does not work, just like all the other miracle cures and snake oils.
According to
http://en.wikipedia.org/wiki/Afterma...economy_device
the EPA, AAA, and Consumer Reports have all found the devices to be ineffective.
See also
http://www.consumerreports.org/cro/c...view/index.htm
Old 06-25-2008, 11:42 AM   #114
TIA
I put one on Rusty years ago, never did reduce anything but the amount of cash in my wallet. I think I paid $60 or $70 for it.
Jay2TheRescue is online now   Reply With Quote
Old 07-11-2008, 09:39 PM   #115
Move close to your work.drive slower.I found this site while researching modifying o2 sensors,i thought mabe leaning out my vehicle would help.my dad recently put on a browns gas type generator and got an immediate 3 mpg increase.
ron17571@netzero.com is offline   Reply With Quote
Old 07-16-2008, 08:29 PM   #116
im new here but reading some of these suggestions and ideas seem to me to that they could do more harm than good and cost more money in the long run. if your doing things like neautral coasting and it causes more wear on ur tranny and hence it may not last as long. running engines at higher operating temps with thermostats and grill blocking and drawing hot air off the manifolds may make for higher combustion temp changes which burns fuel more completely but dont higher temps cause more friction? more friction = more wear = shorter lifespan? charging your batteries overnight to keep em really charged up does the amount of electricity used cost less than the amount of extra fuel used if the batteries r not fully charged? adding solar panels to the car if it could be done in an aerodynamic way would prolly not generate enuff electricity to make much of a difference considering the weight offsets of panels. a 3ft x 1.5 ft panel generates about 15 watts of power under ideal conditions which translates to about 850ma of current i dont think that would over come the extra weight of several pounds of glass. while watching mythbusters they were trying to figger out the tailgate up/down or off idea. when they went to ford for some info and data they were shown in the windtunnel that the tailgate up on a NEW ford pickup enhanced mileage due to the air currents providing a forward push of air pressure that was lost with the gate down or off. on an older truck i dont think this condtion is likely to occur to the same degree, but imho on an older truck a soft lightweight tonneau cover with a lightweight cover replacing the gate would possibly improve FE. another thing i think about does synth oil that costs 7bux a quart when u go thru proper intervals outweigh the cost of the fuel saved? if u do things that make ur car more likely to have a crash or potentially more dangerous resulting in great expense worth the savings in fuel? ive heard some people tell me they get better MPG in vehicles using premium fuel that were meant for regular octane fuel. under ideal conditions this does not make sense when a vehicle is working properly and using the octane that is reccomended for them. some vehicles ive had got lower mileage when running premium over reg octane due to the fact they were not meant to run efficiently with that high and octane rating. I used to run propane vehicles previously. propane has an octane rating of about 110, higher than any pump fuel. but a vehicle ie 83 buick park ave with an olds 307 motor ran about 25% less efficiently than when running gasoline. but at less than half the cost of the fuel at the time it was worth it. if the motor had a compression ratio of say 10 or 11:1 it woulda gotten probably the same kinda mileage over the 8:1 compression it had for gas.
these r just my thots, i dont work for an oil company! LOL, i do think of conservation and i am thinking over many of these ideas and trying to figger for myself if I think they r plausible or foolish., i also like to provoke others to think about em more than just sit and read and think that if its in print on the net its fact. some things work for some some things dont, its all relevant isnt it?
i am curious if you guys/gals give the same kind of thot to conservation of electricity at home to save money as much as you try to conserve ur use of fuel? thots for another thread.
i hope my run on paragraphs dont pee off too many peeps oh yeah im one of those that questions everything, and beleives nothing till its proven to my satisfaction, yeah it ticks my wife off too lol
trollgods is offline   Reply With Quote
Old 07-18-2008, 02:26 PM   #117
Has anyone tried turbulators?
96sc1 is offline   Reply With Quote
Old 07-18-2008, 04:03 PM   #118
Arrow
With conventional oil I change my oil every 3,000. On Synthetic I change every 5,000 so synthetic actually saves me money. Wal-Mart only charges me about $40 for a Mobil-1 synthetic oil change on the Beast.
Old 07-20-2008, 04:21 PM   #119
KARR's Avatar
Country: Portugal
A higher engine temperature will cause the oil viscosity to decrease, making it more fluid, I suppose. If that happens it will actually improve the engine efficiency resulting in a better mileage. Many things you referred are correct, tough.
KARR is offline   Reply With Quote
Old 09-29-2008, 05:55 AM   #120
@ Mr. Brochu:
Remember Login on Mobile page lunawire Fuelly Web Support and Community News 3 08-30-2008 07:33 AM
