Originally Posted by lrichard
I was wondering what people think about coasting in neutral.
Generally, I accelerate upto the speed limit, then put the transmisiion in neutral. I do this in neighborhood driving. With tires inflated to maximum recommended, this allows me to coast for quite a distance before the vehicle slows down enough causing me to put it back in drive. This works well if I am nearing a stop sign. My question is. Could this be harmfull for the vehicles transmission? The tranny seems to shift smoothly from driving to coasting and back.
I have not done this enough to record any possible fuel savings. Mainly due to fears I may be hurting the tranny.
You will get better fuel economy with your foot off the gas and coasting, the engine goes into a lean burn type mode.
When the engine is idling you are using more fuel.
