Lighter flywheel? - Page 2 - Fuelly Forums
Old 08-18-2007, 07:25 PM   #11
I agree that one should not shift without the clutch. It's there for a reason. I rev match all my shifts, it makes for a smoother ride for me and passengers, and is more gentle on the transmission.
TomO, did you just use an engine lathe to turn yours down? I've got access to a 13" engine lathe if I need it. How much runout is permissible?
phantomcow2 is offline   Reply With Quote
Old 08-18-2007, 08:09 PM   #12
GasSavers_TomO's Avatar
It was a CNC lathe. What my friend and I did (he was the one running the machine) was we took off all the backing weight on the OEM flywheel. basically it's all the dead, non-functional weight that Honda put on the back-side. It's the same place they remove some excess weight for the VX flywheel as well. It's been going on 3-4 years now with 262HP and 213ft/lbs of torque going through that lightened flywheel. Recently inspected, it showed no signs of stress fractures or heat scorching even with a 6 puck sprung clutch kit on it.
Honda Civic VX Info/Links
Old 08-19-2007, 11:08 AM   #13
So how thick is it now?
Old 08-19-2007, 11:58 AM   #14
Basically the thickness of the teeth on the flywheel and the mounting surface for the crank.
feature request: updates via text message savraj Fuelly Web Support and Community News 1 08-13-2008 12:21 AM
Boat Tailing a Pickup Snax Aerodynamics 21 03-10-2007 11:52 AM
It happened again! Matt Timion General Fuel Topics 12 09-21-2006 08:26 PM
Measuring Fuel Economy - Instantaneous and Otherwise Mighty Mira General Fuel Topics 12 06-19-2006 05:29 AM
98 civic sedan coefficient of drag? where to find? MetroMPG General Discussion (Off-Topic) 37 02-23-2006 03:26 PM
