Let's talk WAI - Page 3 - Fuelly Forums
Old 01-25-2010, 08:14 AM   #21
Yes, but the more fuel you purchase at one time (ie, wait till the tank is pretty empty) this margin of error gets smaller & smaller.
Old 01-25-2010, 02:13 PM   #22
There's an app for that actually haha. To anyone here who has an ipod or iphone look up Fram Gas Cubby. It just does the pen and paper thing for you.
Okay, here's another idea... Would restricting the air intake opening reduce fuel consumption? I think it will reduce throttle response, basically detuning the car. Less air = less fuel.
drifttec101 is offline   Reply With Quote
Old 01-25-2010, 02:35 PM   #23
Dr. Jerryrigger's Avatar
Very true
The largest margin of error is not the gas pumps decimal place, but how much you fill your tank. I try to top every tank off the same, but I know of no exact method of doing so. I do try to use the same pump, but this only helps a little. But if you think about 50 fill ups, this +- .02gal per fill will obviously balance out, as you only take fuel out one way (hopefully) and your tank doesn't change size.
Back to the WAI (i haven't been online for a wile, so i'm jumping back several posts here)
WAI shouldn't effect burn ratio at all, if you what to lean it out you should bust you O2 sensor reading by 30mV or so (not recommended if you don't have a EGR)
The intake temp matters very little to the computer, just a way of making sure everything is okay.
The benefits as i see them:
1)As stated several times, less air mass needs less fuel to burn in the way that will make your O2 sensor happy.
2)Theoretically (probably true, but may not give mensurable improvements) Hot air will hold fuel vapors better. Thereby your injectors work a little better. This is even more a factor when you think about injected fuel boiling before combustion, which must happen to some degree with a warm block, and high vacume.
Old 01-25-2010, 02:59 PM   #24
WAI doesn't work.
Old 01-25-2010, 04:16 PM   #25
On a modern fuel injected vehicle blocking off part of the air intake will only save gas as well as a block of wood screwed to the back of your accelerator pedal would.
Old 01-25-2010, 05:35 PM   #26
Care to expand on that Jay?
Old 01-25-2010, 06:14 PM   #27
Blocking your intake is doing exactly the same thing is closing the throttle. The only difference is that it's doing it further from the engine.
The throttle is already very good at its job of throttling.
What's more effective in many cars is to shift lower and open the throttle more, so the engine isn't wasting energy on the extra work required to get air past the closed throttle. You produce the same amount of work, accelerate the same, but you use a little less gas because you waste a little less energy.
Old 01-25-2010, 07:36 PM   #28
Thanks HC, that's exactly why blocking off the throttle is like a block on the back of the pedal.
Old 01-26-2010, 12:14 PM   #29
I'm really leaning toward the warm air intake not really doing anything except cutting power to your engine. Just like restricting the air intake inlet will cut power... just like not opening the throttle as much. So really, instead of spending any money on modifications lets all just not accelerate as quickly.
If you want to make your engine truly more efficient then you should reduce rotating intertia within your drivetrain. Lightweight flywheel, gun drilled camshaft, smaller cluth, lightweight pistons etc. All of that is way too expensive to even consider if your goal is to save money on fuel cost.
Reducing friction with exotic ceramic coatins and what not would also help a bunch, but once again it's not practical. The factory engineers already optimized the desgin of aerodynamics with regaurds to functionality and performance, so any gains there are minimal. (Just put tape on your grille for long drives).
Really the only practical thing to do is not drive as much and drive slower when you do drive. Hypermiling is tough on equipment. Like not letting your car warm up on those cold winter mornings is AWFUL for your engine. Maybe you'll save a few bucks but if your engine fails then all that money you've saved goes into repair.
Old 01-26-2010, 12:27 PM   #30
I agree that hypermiling can be hard on the vehicle. I suspect that my transmission problems in my 98 K1500 were due to me hypermiling in a 10 year old vehicle with over 150,000 miles. My Torque Converter started slipping, and that was after a few months of inducing DFCO by downshifting, shifting into Neural at lights, etc. I am now not as extreme in my efforts, balancing economy with wear & tear on the vehicle. The new torque converter + flush & fill the tranny with synthetic ATF cost me about $1,000. I still manage to do a percent or two over EPA estimates with most of my driving being short trip city.
Can't delete fill ups posted by a friend. missmaispace Fuelly Web Support and Community News 4 08-18-2014 10:18 PM
Average mpg + tracked km even though fuel-ups marked as missed Pelle Fuelly Web Support and Community News 14 03-04-2012 04:10 AM
Best ever tank notification - 1st time only? bedbug Fuelly Web Support and Community News 6 05-23-2010 02:51 AM
new member dirtygst Introduce Yourself - New member Welcome 13 03-31-2009 07:46 AM
Column Shifter dletm08 General Discussion (Off-Topic) 6 03-30-2009 10:48 PM
