latest in the belly pan thrash - Fuelly Forums
Old 11-14-2006, 10:10 PM   #1
lovemysan's Avatar
started on the rear tonight. didn't get far. trying to work out the frame. I am also going to have to deal with the TUMOR muffler.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 11-14-2006, 10:12 PM   #2
Sweet dude, I love watching your progress.
Old 11-14-2006, 11:25 PM   #3
Sweet. Eventually I'll get around to adding one, but for now, I'm just longing. I'm too afraid of what a belly pan will do to my engine temp in 90 degree weather on back roads travelling across the state.
Old 11-14-2006, 11:49 PM   #4
The Toecutter's Avatar
How are you going to prevent rust, given the holes you've drilled in the body?
That's a big, big worry for my Triumph GT6!
Old 11-15-2006, 12:17 AM   #5
Paint.
Like DUH !
Old 11-15-2006, 12:28 AM   #6
But is paint alone really sufficient? I've heard horror stories of rust bubbles popping up where people have drilled holes, even after they had painted them over.
Old 11-15-2006, 12:50 AM   #7
omgwtfbyobbq's Avatar
Rust inhibitor then paint?
Old 11-15-2006, 01:01 AM   #8
Rust of course is corrosion of a ferrous metal.
Corrosion requires Oxygen and Water.
To stop corrosion you have to stop either or preferebly both Oxygen and water form contacting the metal.
This can be done with paint., but just as not all paints are the same , not all users preperation of the material to be painted is the same --and this is the important part in prevernting rust.
When drilling a hole in steel it rarely is a clean cut , often leaving burrs.
These burrs on the edge of the hole often have sharp edge with very little surface area for the paint to stick too.
If the paint doesnt cover the metal well it will rust.
So deburr any new holes with either a file or an overside drill bit., and slightly radius the holes edges. (both sides)
The smoother you get the hole the greater chance paint will cover it evenly with no thin spots.
Paint choice is also important.
http://www.por15.com/ has an excellent range of rust inhibiting paints.
I havent used them myslef but they have an excelent rep with hot rodders and restorers world wide.
I have used normal single part epoxy rust proofing paints with great success.
Also another thing to look for ,,if your drilling into a previously painted surface you may lift surounding paint breaking its bond to the metal.
if this happens you must paint over it to seal out air or remove the paint chip and then paint it.
And of course , preperation is 99% of the job.
Prepare well , keep it grease free and paint with good stuff and you wont have rust problems.
PS , if the hole is just for a self tapper screw , use either a zinc plated or galvinized screw and dip the thread into paint before screwing it in.
This will take the paint into the threaded joint (thats what a self tapper does) and seal out air. (hopefully)
if you have access , paint the other side of the screw with paint.
You can also do the same thing with rivets.
Old 11-15-2006, 05:37 AM   #9
lovemysan's Avatar
Short answer = nothing. If this car last me 6-7 years I'll be done with it. And I don't think the belly pan will rust off between no and then.
If I worried about extensive prep of wholes I'd still be on the front of the car.
If I was going to prep them the fastest way would be cold galvanizing spray paint.
I don't think I would install a belly pan on a collector car unless I was willing to take a serious hit in depreciation
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-15-2006, 08:49 AM   #10
"Paint"...
Paint.
Right on! I love your cutting (to the chase) wit! -Ted
Add driver to car already in garage, for shared car ssquid Fuelly Web Support and Community News 1 01-05-2013 02:10 PM
Joint Membership with GasBuddy? Badams Fuelly Web Support and Community News 2 07-02-2011 12:14 AM
I have seen the future of hybrid cars... and here it is Matt Timion Hybrid Vehicles 12 01-22-2006 01:36 PM
IAT Sensor Mod (Resistor Mod) SVOboy General Fuel Topics 28 10-17-2005 07:08 PM
Got my headers today & question 'bout crank scrappers b1gmoose General Fuel Topics 8 10-08-2005 10:49 PM
