Larger/Heavier Flywheel - Page 2 - Fuelly Forums
Old 09-10-2006, 07:36 AM   #11
Yeah that is true so it does add mass to the power train but not all is on the crankshaft smoothing out the power pulses and the fluid is a lot lighter than the steel of a flywheel although I have never seen or picked up a torque converter to know exactly how much they weigh.
Old 09-10-2006, 08:40 AM   #12
Hi JanGeo
The total weight of the torque convertor isnt often realized as they are often mostly empty of oil when you are working with them.
Dropping a 10 inch convertor onto your foot makes you say the worst words imaginable.
Old 09-10-2006, 01:14 PM   #13
Precisely!
If I put a heavier flywheel on the Tempo I bet the two-cylinder mode would be successful.
Precisely! (edit: or harmonic balancers). But we still have to work around the O2 sensor with the blow-by of the pumped air. Next, cylinder hot/cold spots. But good work Tempo guy!
More: Matt, I like the idea of the weights -- like the tilt-a-whirl at the county fair. Intertia will cause things to go to the outer edge.
Someone here mentioned about the OLD FE book where the late 70's cars had a rotating device on the transmission, where on decel, there wouldn't be compression/engine-braking. Where would this fit in? It would be great to pick your foot off of the gas and let the car coast instead of slow-down in an automatic (without shifting to N).
Old 09-10-2006, 04:57 PM   #14
Originally Posted by onegammyleg
Hi JanGeo
Yeah actually the back plate in my BMW is pretty heavy for sure and that isn't the flywheel - just the other half of the clutch surface. I wanted to use the gears from an auto tranny to gear reduce the electric motors I have to do an in hub no suspension off road trail scooter.
Old 09-11-2006, 12:54 AM   #15
Hi rh77 - ?Someone here mentioned about the OLD FE book where the late 70's cars had a rotating device on the transmission, where on decel, there wouldn't be compression/engine-braking. Where would this fit in??
That would have been me that said that.
It was a mod done on a 70's V8 to improve FE.
From what I understood was that it was a freewheeling clutch placed between the gearboxes output shaft and the propshaft.
This made for coasting without the engine braking effect.
It didnt require any controll from the driver , just take your foot off the gas.
I guess it was done with parts from a 4X4 free weeling hub.(some machining tho)
This is the easiest way to set it up on a rear drive car , but placing a new hub on each drive wheel would be better as it even stop the axles from rotating.
In practice tho , one axle may continue to drag a little if the hubs rotating resistance is differnt to the one on the other side.
This could lead to greater wear in the diffs hemishpere.
Same applies to a front drive car.
Fuelly not posting to facebook after deactivate and reactivation of Facebook account. fpage77 Fuelly Web Support and Community News 2 02-14-2012 08:41 AM
feature request: updates via text message savraj Fuelly Web Support and Community News 1 08-13-2008 01:21 AM
Measuring Fuel Economy - Instantaneous and Otherwise Mighty Mira General Fuel Topics 12 06-19-2006 06:29 AM
