 theholycow :) 07-09-2008, 05:49 AM
07-08-2008, 03:31 PM
Killing the engine while revved up: Ok?
When I kill my engine for EOC, it's generally still revving as high as it was in gear, thanks to drive-by-wire rev hang. This could mean 2000 to 3000rpm. Is repeatedly turning off the engine at that speed ok?
07-08-2008, 04:21 PM
I shouldn't think it would be really much different to the ECU itself suddenly cutting fuel in DFCO
07-08-2008, 05:13 PM
Personally I would not do it... I can remember dad yelling at me as a kid when I'd shut off the tractor at high throttle. Dad always said put the throttle on low first before you turn it off. He must have done something right. That little tractor is 53 years old now.
07-08-2008, 05:15 PM
Possibly with a carbed motor the risk would be flooding it and locking it with gas.
07-08-2008, 06:12 PM
Carbed engines will push raw fuel into the exhaust system and when you fire her back up KABOOM!!!!!!!
Ask me how I know LOL, 59 Corvette throttle stuck wide open up to 140 MPH.
Fuel injected, no problem, kill the ignition kill the fuel. Same as high speed DFCO, except you return to idle with ignition on.
regards
gary
07-08-2008, 06:26 PM
Actually you end up with a little extra engine cooling as the water pump is circulating coolent and getting rid of the hot spots in the exhaust areas - I find that my Scion xB engine starts better after I shut it off with a little rev and some open throttle plus it also flushes the exhaust system with some air to remove moisture in the winter time.
07-09-2008, 06:33 AM
I usually let mine settle to idle. It stops much quicker then, with less down-time and more gauge-reading and mileage-counting time. Not sure what difference it makes.
My V-twin lawn tractor mower does that same Kaboom if you shut it down from WOT. Idling for a few seconds first cures it.
07-09-2008, 07:04 AM
My mileage counts even with the ignition off. I intend to add a kill switch eventually.
07-09-2008, 07:42 AM
Does it really? That's interesting. Mine stops for as long as the key is back one notch. As soon as I turn it back to the run position (but engine still off), it starts again. It's only a moment, but one I try to minimize.
