Just bought Civic vx with bad bog problem! - Page 2 - Fuelly Forums
Old 07-21-2008, 09:59 PM   #11
GasSavers_bobski's Avatar
Originally Posted by Jttriesch View Post
How do I pull the stored codes?
Short together the 2 pins of the service check connector (a cut-off U bend from a paper clip works well). The connector should be in the passenger side footwell near the blower motor... It's blue IIRC.
If there are no codes stored, the check engine light will come on and stay on solid as long as the connector is shorted. If there are codes stored, the check engine light will start flashing them out in a repeating series. Short flashes stand for 1, long flashes stand for 10. If there are multiple trouble codes, they will be displayed in order with a short pause between them: 1st code, pause, 2nd code, pause, 3rd code, pause, 1st, pause, 2nd and so on.
Old 07-23-2008, 12:20 AM   #12
I checked using a wire and the CEL just stayed solid -- no codes stored! Damn! Currently my buddy is cleaning out my egr system, hopefully that will do the trick!
Jttriesch is offline   Reply With Quote
Old 07-24-2008, 08:53 AM   #13
It's the TPS sensor, clogged cat, or clogged fuel filter.
Check all of those. The fuel filter is a good cheap starting point.
korax123 is offline   Reply With Quote
Keeping the Automatic Cool rh77 Transmissions and Running Gear 27 01-13-2008 05:18 PM
ICE loads basjoos Experiments, Modifications and DIY 9 11-11-2007 09:32 PM
The civic rattle problem 1993CivicVX General Maintenance and Repair 19 10-07-2007 10:00 PM
Drafting 18-wheelers....revisited Brian D. Hypermiling 26 05-22-2007 02:51 PM
