I want to do some radiator blocking and remove/replace my fan in my car, but the only gauge for temp is my dumb light. So yesterday I jurry rigged a digital food temp thermometer. I extended the wires inside it so I could read the temp inside the car and the other end would be stuck in the radiator somewhere. I bought this sensor originally to see if my engine was overheating and saw that it was very accurate when stuck in a radiator fin (once the 185 degree thermostat opened the reading went to 185).
So right now I have it stuck in the radiator just below where the water comes in from the engine. I did have it down at the bottom of the radiator but it read 120 going down the highway, which was obviously not the temp of the engine.
I am going to be testing it tomorrow to see if the gauge is in a good place. I am hoping this will be accurate so I can move on to some other experiments
If it doesn't work I need to find out what it would cost to put in an aftermarket sensor and gauge. I was seeing ~100 dollars, in which case it wouldn't be worth it.
So far I have gone from 18 with my round trip to work to 22 using P&G and coasting to stop lights to what should be 25 tomorrow when I fill up by adjusting my points. I just got my carb tuned today so I am looking for a slight improvement on the 25 and if I can block my radiator and take my fan off I am hoping for 27 or 28. At which point I will be on the heels of my brother's Civic
Any comments on my sensor and why it will/won't work are welcomed, I will keep this thread updated on my success/failure.
Good night everyone!
Fourthbean
