Yes, driving style is critical for hybrids, as is the route you drive. If you drive secondary roads a lot like I do, the speed limit is generally 30-45 mph. In that setting I can drive a lot on battery only. The same can be said for slow moving traffic on highways. I recommend accelerating with the gas engine up to the speed limit, back off the go pedal for a second or two, then drive under electric power as much as possible. Take advantage of the regenerative braking as much as possible to maintain your battery charge. In general, my battery is never fully charged or depleted. A nice long downhill with a traffic light at the bottom is a great opportunity to recharge that battery!
